Hi, I’be been using a Raspberry Pi2 as a media player for 2 months now. It is connected to the TV in my sitting room. I connect to my PC running Windows 10 in my office using an ethernet network share.
I have several video folders on the HD of my PC and several ext HDDs connected to my PC. On the Raspberry Pi, I set up a SMB share with my PC and it works perfectly for the videos on the HDDs, but not with the folders on my HD. If I try to access the folders on the HD, it shows me a couple of the folders but not all, and the folders it shows me changes every time I try to access them. The sharing permissions are all fine and I have turned off the password requirement in the Network settings of Windows 10. Why does it work with the ext HDDs but not with the HD on my PC?
I set up an UPnP share to access the folders on the HD and it works fine, but only for a day or two. Then I get an error message saying it cannot connect to the network source. So I have to delete the UPnP source and re-install it.
Ideally, I would prefer to use a SMB share for all my folders but don’t really care as long as I can get stable access to my video folders.
Thanks in advance for any help
