currently, I have the following problem.
I want to use a Vero 4k together with an HP EliteDisplay E272q.
But… Kodi let me only select 1080p and not the native resolution of 2560 x 1440.
This resolution isn’t supported at this time.
There were problems with some of the VESA resolutions and the SoC provider recommended discontinuing them.
However, I can now see the following modes are now supported up-stream:
If you have Adjust Refresh Rate (for smooth playback), which we recommend having on, then Vero 4K would switch to 1080p anyway as this is the best format and will offer 23.976Hz.
