Okay…
what if the keyboard don’t write anything
Did you try?! What keyboard?
Yes I did… it’s a no name old keyboard
Maybe the keyboard is broken
Then it will likely take less time to simply re-install fresh…
It’s funny my newest raspberry pi 3 is doing the same and it’s only 3 months old… I haven’t tried with the keyboard…
Doing the same what?
I cant connect through ssh
Because password not accepted?
Than you really should watch out how you secure (passwords and firewalls) your device and also what you install on it
Yes, password not accepted. Means someone or something must have changed it. So suggest to do a clean reinstall and then secure your box
I will make a clean install and change password
