After v15, ‘frame advance’ feature is no longer available.
Maybe the new “Skip steps” broke/disabled it ?
when I ‘press pause then right’ the skip step runs
http://forum.kodi.tv/showthread.php?tid=144460&pid=1532560#pid1532560
thanks!
thanks!
Can you try enabling omxplayer in video/acceleration settings?
(this has always been an omxplayer feature - dvdplayer doesn’t support it).
I have both enabled. Didn’t worked
Enabled only omxplayer. Didn’t worked
‘right’ and ‘left’ keys didn’t changed in remove.xml in /usr/share/kodi/system/keymaps so not a key issue
> <FullscreenVideo>
> <remote>
> <left>StepBack</left>
> <right>StepForward</right>
@popcornmix can you confirm please?
Not currently supported. The skip steps change means the code path that handled frame advance is no longer called.
bug/issue or something that Kodi won’t support anymore?
Not sure. I’ve not seen much evidence of people using it and it’s non-standard (not supported by kodi on other platforms) so possibly it should be dropped.
