Hello!
i have problems with most of fullhd mkv files. the video starts, but after ~ 30 seconds the picture and osmc freeze (can’t access via ssh anymore).
files like this one:
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1 h 4 min
Bit rate : 2 029 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.041
Stream size : 931 MiB (48%)
Writing library : x264 core 119 r2106 07efeb4
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:0.00
Default : Yes
Forced : No
or this one:
Video
Format : AVC
Duration : 1 h 23 min
Bit rate : 3 421 kb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.069
Stream size : 2.00 GiB (83%)
Writing library : x264 core 116 r2037 f8ebd4a
Default : Yes
Forced : No
720p videos or xvid are working.
settings are as suggested here: HD HEVC videos not playing on OSMC August 2021 update - #6 by ActionA
i had to disconnect the rpi and restart, here’s the kodi.log:
https://pastebin.com/tqGwLhVQ
is see a lot of onnect replacing configured host 192.168.178.222 with resolved host 192.168.178.222, does this mean anything?
best regards
