I’ve had my Vero 4K+ for some time and never really had any stutter/freeze issues until now.
Last night I wanted to watch Home Before Dark - S01E01 - [2160p WEB h265][GHOSTS].mkv
General
Unique ID : 173930971202809354948211854213419234862 (0x82D9E2F6396ADBE3590BEFD42F95F62E)
Complete name : Home Before Dark - S01E01 - [2160p WEB h265][GHOSTS].mkv
Format : Matroska
Format version : Version 4
File size : 9.58 GiB
Duration : 54 min 30 s
Overall bit rate : 25.2 Mb/s
Movie name : Home.Before.Dark.S01E01.HDR.2160p.WEB.H265-GHOSTS
Encoded date : UTC 2020-04-22 09:44:07
Writing application : mkvmerge v43.0.0 ('The Quartermaster') 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Video
Format : HEVC
Format profile : Main 10@L5@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 24.4 Mb/s
Width : 3 840 pixels
Height : 1 920 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.138
Stream size : 9.28 GiB (97%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1612 cd/m2
Maximum Frame-Average Light : 157 cd/m2
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 299 MiB (3%)
Title : English
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 51 min 13 s
Bit rate : 53 b/s
Count of elements : 570
Stream size : 19.9 KiB (0%)
Title : English
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Duration : 53 min 16 s
Bit rate : 58 b/s
Count of elements : 659
Stream size : 22.7 KiB (0%)
Title : English [SDH]
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 54 min 15 s
Bit rate : 42 b/s
Count of elements : 584
Stream size : 17.1 KiB (0%)
Title : Dutch
Language : Dutch
Default : No
Forced : No
My Vero 4K+ is hooked through 1Gbit back to a Windows 2019 Server
Network does not have any issues and is stable, I’m not using fstab just normal smb
osmc@HTPC1:~$ iperf3 -R -c 192.168.2.201
Connecting to host 192.168.2.201, port 5201
Reverse mode, remote host 192.168.2.201 is sending
[ 4] local 192.168.2.50 port 48003 connected to 192.168.2.201 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 109 MBytes 911 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 942 Mbits/sec
[ 4] 2.00-3.00 sec 108 MBytes 907 Mbits/sec
[ 4] 3.00-4.00 sec 112 MBytes 943 Mbits/sec
[ 4] 4.00-5.00 sec 113 MBytes 944 Mbits/sec
[ 4] 5.00-6.00 sec 113 MBytes 945 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 941 Mbits/sec
[ 4] 7.00-8.00 sec 111 MBytes 930 Mbits/sec
[ 4] 8.00-9.00 sec 113 MBytes 946 Mbits/sec
[ 4] 9.00-10.00 sec 111 MBytes 935 Mbits/sec
[ 4] 0.00-10.00 sec 1.09 GBytes 935 Mbits/sec sender
[ 4] 0.00-10.00 sec 1.09 GBytes 935 Mbits/sec receiver
iperf Done.
osmc@HTPC1:~$ iperf3 -c 192.168.2.201
[ 4] local 192.168.2.50 port 48006 connected to 192.168.2.201 port 5201
[ 4] 0.00-1.01 sec 110 MBytes 918 Mbits/sec 0 269 KBytes
[ 4] 1.01-2.00 sec 112 MBytes 943 Mbits/sec 0 269 KBytes
[ 4] 2.00-3.00 sec 113 MBytes 945 Mbits/sec 0 269 KBytes
[ 4] 3.00-4.00 sec 113 MBytes 946 Mbits/sec 0 269 KBytes
[ 4] 4.00-5.00 sec 113 MBytes 947 Mbits/sec 0 269 KBytes
[ 4] 5.00-6.00 sec 113 MBytes 944 Mbits/sec 0 269 KBytes
[ 4] 6.00-7.00 sec 113 MBytes 948 Mbits/sec 0 269 KBytes
[ 4] 7.00-8.00 sec 111 MBytes 933 Mbits/sec 13 215 KBytes
[ 4] 8.00-9.00 sec 113 MBytes 949 Mbits/sec 0 244 KBytes
[ 4] 9.00-10.00 sec 111 MBytes 934 Mbits/sec 0 261 KBytes
[ 4] 0.00-10.00 sec 1.10 GBytes 941 Mbits/sec 13 sender
[ 4] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec receiver
iperf Done.
During playback it would just freeze the video while the audio continued. The progress bar in Kodi still showed a healty buffer.
I did try to play the video on my laptop and it does not hang in the same places as the Vero so it does not appear to be part of the actual video.
I play 2160P Bluray Remux of Movies without issue but this file just freezes
For instance just watched this one without a single freeze or stutter
General
Unique ID : 313494806448878647232106056994175776913 (0xEBD8E74CC1F04A3F22B005213ECAF891)
Complete name : Godzilla King of the Monsters (2019) - [Remux-2160p][HEVC HDR][TRUEHD ATMOS 7.1][EN][EPSiLON].mkv
Format : Matroska
File size : 56.2 GiB
Duration : 2 h 11 min
Overall bit rate : 61.1 Mb/s
Movie name : Godzilla: King of the Monsters (2019)
Encoded date : UTC 2019-08-19 17:02:59
Writing application : mkvmerge v35.0.0 ('All The Love In The World') 64-bit
Writing library : libebml v1.3.9 + libmatroska v1.5.2
IMDB : tt3741700
TMDB : movie/373571
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate : 56.4 Mb/s
Height : 2 160 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.284
Stream size : 51.9 GiB (92%)
Title : MPEG-H HEVC Video / 56422 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10+ / BT.2020
Language : English
Default : Yes
Forced : No
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1998 cd/m2
Maximum Frame-Average Light : 414 cd/m2
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 797 kb/s
Maximum bit rate : 6 537 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.49 GiB (6%)
Title : Dolby TrueHD/Atmos Audio / 7.1 / 48 kHz / 4245 kbps / 24-bit
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate : 448 kb/s
Stream size : 422 MiB (1%)
Title : Commentary by co-writer/co-director Michael Dougherty, co-writer Zach Shields and actor O'Shea Jackson Jr.
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Stream size : 181 MiB (0%)
Title : Compatibility Track / Dolby Digital Audio / 5.1-EX / 48 kHz / 448 kbps
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 33.0 kb/s
Count of elements : 3322
Stream size : 31.0 MiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Duration : 2 h 10 min
Bit rate : 15.5 kb/s
Count of elements : 2746
Stream size : 14.5 MiB (0%)
Language : Arabic
Default : No
Forced : No
Text #3
Format : PGS
Bit rate : 23.5 kb/s
Count of elements : 2816
Stream size : 22.0 MiB (0%)
Title : Cantonese
Language : Chinese
Default : No
Forced : No
Text #4
Format : PGS
Bit rate : 25.4 kb/s
Count of elements : 2492
Stream size : 23.7 MiB (0%)
Title : Mandarin Traditional
Language : Chinese
Default : No
Forced : No
Text #5
Format : PGS
Bit rate : 23.9 kb/s
Count of elements : 2552
Stream size : 22.3 MiB (0%)
Language : French
Default : No
Forced : No
Text #6
Format : PGS
Count of elements : 2718
Language : Korean
Default : No
Forced : No
Text #7
Format : PGS
Bit rate : 28.0 kb/s
Count of elements : 2784
Stream size : 26.2 MiB (0%)
Title : Latin American
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:10:53.903 : en:Chapter 2
00:18:06.836 : en:Chapter 3
00:30:27.325 : en:Chapter 4
00:45:18.633 : en:Chapter 5
00:54:11.039 : en:Chapter 6
01:05:41.646 : en:Chapter 7
01:09:31.584 : en:Chapter 8
01:19:31.308 : en:Chapter 9
01:30:06.234 : en:Chapter 10
01:38:36.869 : en:Chapter 11
01:49:58.884 : en:Chapter 12
01:59:28.828 : en:Chapter 13
Let me know what else you need to troubleshoot this.
