Vero 4K is OSMC’s flagship device. We’ve taken some time to answer the most common questions you may have about it.
How do I change the Vero remote battery?
The Vero remote uses a CR2032 battery. This type of battery is also used in watches and can be obtained from most jewellers. You may however find these batteries cheaper online. You should only need to replace your battery once every couple of years.
Please note that the battery is not covered under warranty as it is considered a consumable.
Can I reinstall OSMC?
Yes – please see this article for more information on how to reload OSMC on your Vero 4K.
How do I get support for my device?
Please check the Wiki to see if your question has been covered. We also have a community forum if you would like to ask a question or discuss OSMC with other Vero 4K owners.
You can also contact us directly for support.
