I just got a RPi 4 and am doing a fresh install of OSMC. I have tried the new 2023.08.01 as well as the 2023.07.01 bersiond from the installer, but get the same issues.
Samba doesn’t appear to be running. I configured what I could find in the menus, but no change. Also, I cannot launch the Store app from OSMC, not sure this is related, but I used to go there to “install” it.
Suggestions?
reproduce the issue
upload the log set (all configs and logs!) either using the
Thanks, I reverted to the 2023.01.01 build and got samba configured and the menu worked then updated to a recent build.
I also was getting errors about “couldn’t connect to server” for add-ons, but when I enabled debug logging, it started working. Turned it off, and still is working.
I can still submit logs if you want, but not noticing any more issues at the moment.
