FSTAB CIFS mount not working after kodi update
Hi Tom,
there is no need for further activities in my case. The solution is the connecting via SMB:// without mounting. So thanks.
hans
have a nice time
The requested outputs:
osmc@raspi:~$ sudo mount -a
osmc@raspi:~$
osmc@raspi:~$ sudo mount -v /mnt/MEDIA
Couldn’t chdir to /mnt/MEDIA: No such device
osmc@raspi:~$
Also, i have tried this:
Login via the command line
Edit the file /etc/apt/sources.list
Add the following line: deb http://apt.osmc.tv stretch-devel main
…but it does not work. Nothing happens.
Tried adding vers=1.0 , 1.01, 2.0, 3.0, 3.02 but nothing works.
Something a little more descriptive would help here…
That simply means the directory /mnt/MEDIA does not exist or is not accessible by wrong permissions. If it should exist, remove it and reboot. It will be recreated if it is a mountpoint in fstab. If it does not exist reboot also to let it create.
OK, i followed your advice. Unmounted /mnt/MEDIA, then deleted it. Afterwards i rebooted the device and the MEDIA directory got created by the fstab line, as you said, but still there was no mount.
again i issued sudp mount -a and sudo mount -v /mnt/MEDIA. For the last command, now i got error “Host down”. Tried to ping the share server from the raspberry and i got reply OK, so again i got stuck. I searched on the internet for more smb tshooting and i issued these commands:
osmc@raspi:~$ smbclient -L 10.2.2.249 -U Administrator
WARNING: The “syslog” option is deprecated
Enter Administrator’s password:
protocol negotiation failed: NT_STATUS_CONNECTION_RESET
osmc@raspi:~$ smbclient -L 10.2.2.249 -U Administrator -m SMB2
session setup failed: NT_STATUS_ACCESS_DENIED
osmc@raspi:~$ smbclient -L 10.2.2.249 -U Administrator -m SMB3
Domain=[NGDC] OS= Server=
    Sharename       Type      Comment
    ADMIN$          Disk      Remote Admin
    C$              Disk      Default share
    E$              Disk      Default share
    F$              Disk      Default share
    IPC$            IPC       Remote IPC
    IT              Disk
    MEDIA           Disk
Connection to 10.2.2.249 failed (Error NT_STATUS_RESOURCE_NAME_NOT_FOUND)
NetBIOS over TCP disabled – no workgroup available
osmc@raspi:~$
So although there were errors, the SMB3 version command seemed to work. So i went again to the fstab entry and added “vers=3.0” again for i don’t know how times. Issued again sudo mount -a => no result, then sudo mount -v /mntMEDIA and surprise; it did not show any errors anymore.
I checked and the share got finally mounted. I really cannot explain why, because i did these steps before, for several times, with no success.
The share now gets automonted at reboot and also with command sodu mount -v /mnt/MEDIA
i don’t understand why sudo mount - a is not working anymore.
Conclusion:adding"vers=3.0" in the fstab entry solved the issue.
Happened the same thing to me. I solved by adding “vers=3.0” to fstab. Thank you.
Got the same error about mount error(22): Invalid argument using the fstab to mount a cifs on a Zyxel NAS540, since I updated osmc today.
Fstab used to work using the following pattern
//Source/path /mnt/path cifs username=User,password=xxx
Tried adding the vers=1.0/3.0 to the fstab linr and also succesfully applied the updates using
sudo apt-get update && sudo apt-get dist-upgrade && reboot.
Tried to delete the mount folders, too.
Nothing helped.
Hi BenniV,
So, in summary:
  • activate the logging
  • reboot the OSMC device
  • upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Thanks Tom.
