I have a Vero4K+ running Bullseye running Nov 2022 OSMC version.
I have a number of network shares setup that worked for a long time but not I can no longer connect from the Vero4K+ to those shares.
Here is one FSTAB entry. //192.168.0.100/Multimedia/Movies /home/osmc/qnap/Movies cifs x-systemd.automount,auto,rw,iocharset=utf8,username=,password=,uid=osmc,gid=osmc,file_mode=0770,dir_mode=0770 0 0
When I do a mount -av. The error I receive is "Couldn’t chdir to /home/osmc/qnap/Movies: No such device.
I may have a corrupted file system but I don’t know much about the inner workings of Linux. Any help is appreciated.
As you have fstab entries I assume you know how to SSH to the Vero. Let’s do some checks (copy/paste the output):
ls -lah /home/osmc/qnap
Suggest to install smbclient (sudo apt install smbclient) no need to share that info and then run the command: smbclient -L 192.168.0.100 and copy/paste
Could try to add in your fstab line vers=2.1 but let’s first see what the commands above give
Sharename Type Comment
Public Disk System default share
Multimedia Disk System default share
SMB1 disabled -- no workgroup available
I don’t know where to place the version info in the fstab line though.
I have unmounted the previous connections. I can now cd into the folder.
When I use this command in the fstab file I get the following error when I try to sudo mount -av
Finally found a dmesg error of -95. This led me to add in a vers=3.0 at the end of fstab as previously mentioned. Apparently when the QNAP NAS drive last updated it disabled SMB1.
Yes. It is. I scoured the internet for the phrase “No such device” in relation to FSTAB and I could not find anything. I appreciate the clues that were given to find and fix the problem.
