I’m on a RP3.
I have playback issue so i’m trying to get the log from Kodi but i don’t know to access to the RP3. I installed the FTP server, but i can’t access ti the files.
Any idea ?
KS
I’m on a RP3.
Any idea ?
KS
I would not suggest to use ftp for that.
Use SSH/SFTP.
If you have Windows machine can use putty.
But you also can use the log upload in MyOSMC than you can read the log files in the browser
Thank you for your answer.
I’m on Mac & i don’t know how to use SSH.
The idea is to search the log for errors and, if necessary, to post it on Kodi community.
http://accc.uic.edu/answer/how-do-i-use-ssh-and-sftp-mac-os-x
As mentioned just use log uploader from MyOSMC than you can read them in Web browser and share what you believe explains your issue
