hi guys,
quick question, i try to ftp from my seedbox to my osmc rpi but seems like all transfers fail. i’m connected through FTPRUSH as filezilla doesnt allow site 2 site transfer
This might be of some assistance:
vsftpd-fxp
thanks but still doesn’t work
looks like i completly killed vsftpd now
osmc@osmc:~$ systemctl status vsftpd
* vsftpd.service - vsftpd FTP server
Loaded: loaded (/lib/systemd/system/vsftpd.service; enabled)
Active: failed (Result: exit-code) since Mon 2017-10-16 20:56:22 WEST; 9s ago
Process: 32108 ExecStart=/usr/sbin/vsftpd /etc/vsftpd.conf (code=exited, status=2)
Process: 32106 ExecStartPre=/bin/mkdir -p /var/run/vsftpd/empty (code=exited, status=0/SUCCESS)
Main PID: 32108 (code=exited, status=2)
i think its because i did this
osmc@osmc:~$ sudo /etc/init.d/vsftpd restart
[ ok ] Restarting vsftpd (via systemctl): vsftpd.service.
-- Logs begin at Thu 1970-01-01 00:00:04 WET, end at Mon 2017-10-16 21:04:52 WEST. --
Oct 16 21:04:11 osmc systemd[1]: Started vsftpd FTP server.
-- Subject: Unit vsftpd.service has finished start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit vsftpd.service has finished starting up.
-- The start-up result is done.
Oct 16 21:04:11 osmc sudo[32229]: pam_unix(sudo:session): session closed for user root
Oct 16 21:04:11 osmc systemd[1]: vsftpd.service: main process exited, code=exited, status=2/INVALIDARGUMENT
Oct 16 21:04:11 osmc systemd[1]: Unit vsftpd.service entered failed state.
Oct 16 21:04:29 osmc sudo[32241]: osmc : TTY=pts/0 ; PWD=/home/osmc ; USER=root ; COMMAND=/bin/systemctl reload vsftpd
Oct 16 21:04:29 osmc sudo[32241]: pam_unix(sudo:session): session opened for user root by osmc(uid=0)
Oct 16 21:04:29 osmc systemd[1]: Unit vsftpd.service cannot be reloaded because it is inactive.
Oct 16 21:04:29 osmc sudo[32241]: pam_unix(sudo:session): session closed for user root
Oct 16 21:04:52 osmc sudo[32244]: osmc : TTY=pts/0 ; PWD=/home/osmc ; USER=root ; COMMAND=/bin/journalctl -xn
Oct 16 21:04:52 osmc sudo[32244]: pam_unix(sudo:session): session opened for user root by osmc(uid=0)
Nope. It’s likely to be something else. If you’ve configured it, look there. Here’s a brand new install of vsftpd.
● vsftpd.service - vsftpd FTP server
Active: active (running) since Mon 2017-10-16 21:12:27 BST; 2min 55s ago
Main PID: 2709 (vsftpd)
CGroup: /system.slice/vsftpd.service
└─2709 /usr/sbin/vsftpd /etc/vsftpd.conf
Active: active (running) since Mon 2017-10-16 21:17:46 BST; 16s ago
Process: 2766 ExecStartPre=/bin/mkdir -p /var/run/vsftpd/empty (code=exited, status=0/SUCCESS)
Main PID: 2769 (vsftpd)
└─2769 /usr/sbin/vsftpd /etc/vsftpd.conf
Ideally, you should be using sudo systemctl restart vsftpd
now, rather than sudo /etc/init.d/vsftpd restart
yes now i fixed it as it seems the .conf got corrupted. i copied the one from osmc github but now it keeps asking me for user and pass eventhough i already input them.maybe you can upload urs?or a default one
EDIT: GOt in but still can’t fxp
500 OOPS: vsf_sysutil_bind
vsftpd.conf
osmc@osmc:~$ cat /etc/vsftpd.conf
# Example config file /etc/vsftpd.conf
# The default compiled in settings are fairly paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# Please see vsftpd.conf.5 for all compiled in defaults.
# READ THIS: This example file is NOT an exhaustive list of vsftpd options.
# Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
# capabilities.
# Run standalone? vsftpd can run either from an inetd or as a standalone
# daemon started from an initscript.
listen=NO
# This directive enables listening on IPv6 sockets. By default, listening
# on the IPv6 "any" address (::) will accept connections from both IPv6
# and IPv4 clients. It is not necessary to listen on *both* IPv4 and IPv6
# sockets. If you want that (perhaps because you want to listen on specific
# addresses) then you must run two copies of vsftpd with two configuration
# files.
listen_ipv6=YES
# Allow anonymous FTP? (Disabled by default).
anonymous_enable=NO
# Uncomment this to allow local users to log in.
local_enable=YES
# Uncomment this to enable any form of FTP write command.
#write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
#local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# If enabled, vsftpd will display directory listings with the time
# in your local time zone. The default is to display GMT. The
# times returned by the MDTM FTP command are also affected by this
# option.
use_localtime=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# You may override where the log file goes if you like. The default is shown
# below.
#xferlog_file=/var/log/vsftpd.log
# If you want, you can have your log file in standard ftpd xferlog format.
# Note that the default log file location is /var/log/xferlog in this case.
#xferlog_std_format=YES
# You may change the default value for timing out an idle session.
#idle_session_timeout=600
# You may change the default value for timing out a data connection.
#data_connection_timeout=120
# It is recommended that you define on your system a unique user which the
# ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that on some FTP servers, ASCII support allows a denial of service
# attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd
# predicted this attack and has always been safe, reporting the size of the
# raw file.
# ASCII mangling is a horrible feature of the protocol.
#ascii_upload_enable=YES
#ascii_download_enable=YES
# You may fully customise the login banner string:
#ftpd_banner=Welcome to blah FTP service.
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# You may restrict local users to their home directories. See the FAQ for
# the possible risks in this before using chroot_local_user or
# chroot_list_enable below.
#chroot_local_user=YES
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
# (Warning! chroot'ing can be very dangerous. If using chroot, make sure that
# the user does not have write access to the top level directory within the
# chroot)
#chroot_list_enable=YES
# (default follows)
#chroot_list_file=/etc/vsftpd.chroot_list
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
# Customization
# Some of vsftpd's settings don't fit the filesystem layout by
# default.
# This option should be the name of a directory which is empty. Also, the
# directory should not be writable by the ftp user. This directory is used
# as a secure chroot() jail at times vsftpd does not require filesystem
# access.
secure_chroot_dir=/var/run/vsftpd/empty
# This string is the name of the PAM service vsftpd will use.
pam_service_name=vsftpd
# This option specifies the location of the RSA certificate to use for SSL
# encrypted connections.
rsa_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
rsa_private_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
ssl_enable=NO
It works on my LAN (no configuration):
ftp 192.168.8.33
Connected to 192.168.8.33 (192.168.8.33).
220 (vsFTPd 3.0.2)
Name (192.168.8.33:user): osmc
331 Please specify the password.
Password:
230 Login successful.
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> quit
221 Goodbye.
thanks but did you try fxping between 2 FTPs?
[T] PROT C
[T] Connexion en cours a ftp://osmc:***@192.xxxxxxxx
[T] Connexion en cours a 192.xxxxxxx:21
[T] 220 OSMC FTP Server
[T] USER osmc
[T] 331 Please specify the password.
[T] PASS (hidden)
[T] 230 Login successful.
[T] SYST
[T] 215 UNIX Type: L8
[T] TYPE A
[T] 200 Protection set to Clear
[T] PASV
[T] 200 Switching to ASCII mode.
[T] FEAT
[T] 211-Features:
[T] EPRT
[T] EPSV
[T] MDTM
[T] PASV
[T] REST STREAM
[T] SIZE
[T] TVFS
[T] 211 End
[T] PWD
[T] 257 “/home/osmc”
[T] 227 Entering Passive Mode (37,48,111,139,248,165).
[T] PORT 37,48,111,139,248,165
[T] 200 PORT command successful. Consider using PASV.
[T] STOR test2.txt
[T] 500 OOPS: vsf_sysutil_bind
No. I only did what I posted,
ok, need to figure out what the 500 vsf_sysutil_bind error means
