Hello all i have pi zero and also wifi adapter TL-WN725N V2
on raspbian i use this tutorial Raspberry Pi Zero USB/Ethernet Gadget Tutorial - Circuit Basics
to connect my pi to my pc and to install driver i use (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.xx.xx+ - Raspberry Pi Forums
and its work perfect so on osmc i can make it work
can somebody help how can i install this drive in situation when i dont have any hub and cant compile kernel and add driver i only want use method
Unfortunately support for many Realtek based wifi adapters have been dropped.
That seems to use the Realtek 8188eu driver. I can’t speak for the Pi Zero, but the r8188eu driver has reappeared on my Pi 3.
osmc@osmc:~$ modinfo r8188eu
filename: /lib/modules/4.19.122-1-osmc/kernel/drivers/staging/rtl8188eu/r8188eu.ko
version: v4.1.4_6773.20130222
author: Realtek Semiconductor Corp.
description: Realtek Wireless Lan Driver
license: GPL
srcversion: 337F9C883F2FCAFC0D7F09D
alias: usb:v0BDApFFEFd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0DF6p0076d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2C4Ep0102d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p0111d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2357p010Cd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p331Bd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p3311d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p3310d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2001p330Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0B05p18F0d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v07B8p8179d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v056Ep4008d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp0179d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp8179d*dc*dsc*dp*ic*isc*ip*in*
depends: cfg80211,lib80211
staging: Y
intree: Y
vermagic: 4.19.122-1-osmc SMP preempt mod_unload modversions ARMv7 p2v8
< the rest snipped >
The reference to staging is interesting, but I’m definitely on the (latest) stable build.
Staging refers to drivers in the Linux kernel that aren’t quite considered stable yet. They are then eventually moved to the appropriate subsystem.
