Hi all,
I have a couple of questions regarding library setup.
I have folders setup on an external HDD. Movies is one of the folders and TV Shows is the other. No matter how I try, I can not get anything to show in the TV Shows area of the home menu. If I scroll to movies the movies are there. If I scroll to TV Shows it has the option of ‘enter files section’ or remove this main menu item. No matter what option I select it always stays blank. Any ideas on wha might be causing me this issue?
In my movies folder I have some full blu ray folders. Within these folders are loads of files that on their own do not make up the movie. Many different stream files. On the ‘Movies’ main menu sea where you can see all the movie art there are hundreds of ‘stream’ posters and only 4 actual movie posters. I understand that it must be looking within the folder and taking everything as a potential video file to play. How do I stop that? Can I select just one image for the whole folder somehow?
Thanks in advance for any help.
