Hi i’m new to OSMC and would like to know a few basic things about Kodi/OSMC.
I want to mess around with all the different addons from different Repositories and i know that unofficial repos can always bear the risk to contain malware and what not, but does OSMC or Kodi run itself as root?
Do Addons have any kind of root access withing Kodi or is it all run as user OSMC?
I heard that there was some troubles with the Xbox360 Wireless Controller (double input) and would like to know if this has been fixed in OSMC Jarvis/16 and if so is there are good tutorial on how to get it running?
I know that it is automatically recognized within Krypton-Builds and i really would love to stay with your Krypton Alpha-Builds as they are pretty much rock solid in most regards but sadly nether my HifiDIY DAC’s nor my Audioquest Dragonfly work within the Krypton Builds.
Btw. I took my Raspberry microsd and tried change the permissions of config.txt to 777 but for some unknown reason this didn’t work nether from my regular nor from a live cd of Debian is there some magic going on there?
I can edit and save the file as root but i don’t seem to be able to change the rights on that specific file to 777 (obviously without rebooting it on the RPi)
Is it technically possible to change something about the root dilemma?
Is there any reason to grant Kodi/XMBC root-access in the first place or why did OSMC went down that route instead of using a separate account in which all the Kodi Stuff runs?
Normally there is this rule of thumb that goes ‘never run anything as root that doesn’t have the necessity of root access’
osmc@osmc:~$ sudo cat /etc/sudoers
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults env_reset
Defaults mail_badpass
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root ALL=(ALL:ALL) ALL
# Allow members of group sudo to execute any command
%sudo ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
Something is not right with your system then. You should have /etc/sudoers.d/osmc-no-sudo-password which doesn’t enforce password on sudo. Are you saying the following command prompts for password?
