Are you running all those commands as root including the pip command ? BTW when I needed to install PIP to use a Python debugger I didn’t install it via APT package, I just did:
Yes, I set a root password and use that to set everything up.
PIP installed fine (I did re-install using your instructions, which also worked fine). My knowledge level is very low with linux, most of what I have done I have learnt from other forum posts, so I am not sure I even need all of the things I am doing - I just know that they worked fine is Raspbmc.
Moving to OSMC has meant changing a lot of my backed up files so that paths point to the right place. I now have everything else working except this. I appreciate this is not something most people would mess around with, but would really like to have everything working as before.
may be slightly naive on the maintainer’s part as it attempts to invoke a cross compiler. Try running the following commands before that pip install command:
i got it installed, but i always have to run the script with sudo.
is there a way to get access rights?
i’d like to write a kodi addon for rotary encoders.
