I have three osmc devices - one RPI4, one Vero 4K and the new Vero V.
I installed the advancedsettings.xml, sources.xml and passwords.xml
The Gui now hangs in an restart loop…
if i remove advancedsettings.xml, the restart loop stopps.
Here’s the kodi.log
2025-06-05 20:02:47.363 T:4543 info <general>: -----------------------------------------------------------------------
2025-06-05 20:02:47.363 T:4543 info <general>: Starting Kodi (21.2). Platform: Linux ARM 32-bit (version for Vero)
2025-06-05 20:02:47.363 T:4543 info <general>: Using Release Kodi x32
2025-06-05 20:02:47.363 T:4543 info <general>: Kodi compiled 2025-02-20 by GCC 10.2.1 for Linux ARM 32-bit version 5.10.158 (330398)
2025-06-05 20:02:47.363 T:4543 info <general>: Running on OSMC Vero V with Open Source Media Center 2025.03-1, kernel: Linux ARM 32-bit version 4.9.269-80-o
smc
2025-06-05 20:02:47.363 T:4543 info <general>: FFmpeg version/source: 6.0.1-Kodi
2025-06-05 20:02:47.363 T:4543 info <general>: 4 CPU cores available
2025-06-05 20:02:47.363 T:4543 info <general>: ARM Features: Neon disabled
2025-06-05 20:02:47.363 T:4543 info <general>: special://xbmc/ is mapped to: /usr/share/kodi
2025-06-05 20:02:47.363 T:4543 info <general>: special://xbmcbin/ is mapped to: /usr/lib/kodi
2025-06-05 20:02:47.363 T:4543 info <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2025-06-05 20:02:47.363 T:4543 info <general>: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
2025-06-05 20:02:47.363 T:4543 info <general>: special://envhome/ is mapped to: /home/osmc
2025-06-05 20:02:47.363 T:4543 info <general>: special://home/ is mapped to: /home/osmc/.kodi
2025-06-05 20:02:47.364 T:4543 info <general>: special://temp/ is mapped to: /home/osmc/.kodi/temp
2025-06-05 20:02:47.364 T:4543 info <general>: special://logpath/ is mapped to: /home/osmc/.kodi/temp
2025-06-05 20:02:47.364 T:4543 info <general>: Webserver extra whitelist paths:
2025-06-05 20:02:47.364 T:4543 info <general>: The executable running is: /usr/lib/kodi/kodi.bin
2025-06-05 20:02:47.364 T:4543 info <general>: Local hostname: vero4k-wz
2025-06-05 20:02:47.364 T:4543 info <general>: Log File is located: /home/osmc/.kodi/temp/kodi.log
2025-06-05 20:02:47.364 T:4543 info <general>: -----------------------------------------------------------------------
2025-06-05 20:02:47.364 T:4543 info <general>: loading settings
2025-06-05 20:02:47.365 T:4543 info <general>: special://profile/ is mapped to: special://masterprofile/
2025-06-05 20:02:47.391 T:4543 info <general>: Loaded settings file from special://xbmc/system/advancedsettings.xml
2025-06-05 20:02:47.393 T:4543 info <general>: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Do not modify! These are OSMC optimised settings for your device !-->
<!-- If you wish to override any of these values, then create a file in /home/osmc/.kodi/userdata/advancedsettings.xml !-->
<!-- It will override these settings, and your settings will be preserved across OSMC updates !-->
<advancedsettings version="1.0">
<imageres>540</imageres>
<fanartres>720</fanartres>
<splash>false</splash>
<handlemounting>false</handlemounting>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cputempcommand>/bin/sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</cputempcommand>
<gputempcommand>/bin/sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</gputempcommand>
<gamesgeneral>
<enable>true</enable>
</gamesgeneral>
<videoscreen>
<screen>0</screen>
</videoscreen>
<myvideos>
<usetags>false</usetags>
</myvideos>
<video>
<excludefromscan action="append">
<regexp>(?i)(@eadir|system.volume.information|\$recycle)</regexp>
</excludefromscan>
<excludefromlisting action="append">
</excludefromlisting>
</audio>
</advancedsettings>
2025-06-05 20:02:47.395 T:4543 info <general>: Loaded settings file from special://profile/advancedsettings.xml
2025-06-05 20:02:47.396 T:4543 info <general>: Contents of special://profile/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<loglevel>5</loglevel>
<videodatabase>
<type>mysql</type>
<name>kodivideodb</name>
<host>192.168.2.73</host>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<name>kodimusicdb</name>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
<pathsubstitution>
<substitute>
<from>special://masterprofile/sources.xml</from>
<to>nfs://192.168.2.73/kodidb/settings/sources.xml</to>
</substitute>
<substitute>
<from>special://masterprofile/passwords.xml</from>
<to>nfs://192.168.2.73/kodidb/settings/passwords.xml</to>
</substitute>
</pathsubstitution>
</advancedsettings>
2025-06-05 20:02:47.396 T:4543 debug <general>: Configuring path substitutions
2025-06-05 20:02:47.396 T:4543 debug <general>: Registering substitution pair:
2025-06-05 20:02:47.396 T:4543 debug <general>: From: [/home/osmc/.kodi/userdata/sources.xml]
2025-06-05 20:02:47.396 T:4543 debug <general>: To: [nfs://192.168.2.73/kodidb/settings/sources.xml]
2025-06-05 20:02:47.396 T:4543 debug <general>: From: [/home/osmc/.kodi/userdata/passwords.xml]
2025-06-05 20:02:47.396 T:4543 debug <general>: To: [nfs://192.168.2.73/kodidb/settings/passwords.xml]
2025-06-05 20:02:47.396 T:4543 warning <general>: VIDEO database configuration is experimental.
2025-06-05 20:02:47.396 T:4543 warning <CSettingsManager>: missing version attribute
2025-06-05 20:02:47.397 T:4543 info <general>: Default Video Player: VideoPlayer
2025-06-05 20:02:47.397 T:4543 info <general>: Default Audio Player: paplayer
2025-06-05 20:02:47.397 T:4543 info <general>: Disabled debug logging due to GUI setting. Level 1.
There’s no more log
and that’s my advancedsettings.xml
<?xml version="1.0" encoding="utf-8"?>
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>****</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</musicdatabase>
<videolibrary>
</videolibrary>
<pathsubstitution>
<substitute>
</substitute>
<substitute>
</substitute>
</pathsubstitution>
</advancedsettings>
