As many of you,
I’m using transmission to remotely connect to my osmc machine (Raspeberry Pi 3) and configure some downloads into an ÚSB attached HDD.
I’ve defined a user and password in:
~/.config/transmission-daemon/settings.json
And using a web browser to connect to
http:/my.ipadress.xxx:9091.
Also using the windows application “transmission remote gui” as a remote interface that runs in windows.
Unfortunately, all this is very nice but communicates openly with my Pi in pure http.
How to do it in https (SSL) ???
After some investigation I’ve opted to use nginx as a SSL REVERSE PROXY.
- Install as simple as:
sudo apt-get install nginx
- Generate some keys with openssl (pay attention to what will be requested):
sudo openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/nginx/cert.key -out /etc/nginx/cert.crt
- edit the config file:
/etc/nginx/sites-enabled/default
In this example I’ve opted to forward https requests in port 2443 to http 9091 and using server name my.ipaddress.com
You should replace for your choosen port and server name:
# Transmission ssl redirect
# https:2443 to http:9091
server {
listen 2443;
server_name my.ipaddress.com;
ssl_certificate /etc/nginx/cert.crt;
ssl_certificate_key /etc/nginx/cert.key;
ssl on;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
ssl_prefer_server_ciphers on;
access_log /var/log/nginx/nginx-2443.log;
location / {
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
# Fix the .It appears that your reverse proxy set up is broken" error.
proxy_pass http://localhost:9091;
proxy_read_timeout 90;
proxy_redirect http://localhost:9091 https://my.ipaddress.com:2443;
- Now, restart nginx service:
sudo service nginx restart
- And try access trough:
NOTE:
I’ve used many sources and tests to come to this, but as a cross reference I suggest a quick look into the following links:
https://www.carrier-lost.org/raspberry-pi-nginx-webserver-with-php-and-ssl/
NOTE:
You can easily edit
to add a second server in order to also access kodi remote trough https.
[EDIT]
@admins @sam_nazarko : I’m sorry but It seems I’ve misplaced this topic in the wrong place, may you please move it to the correct category ? (“how-to” ???). Thanks
