Stumped as to why this could be, higher bandwidth h264 seems fine,and they sdem fine on my other vero4 that’s wired. Any ideas?
Take it back, seems the same with most files. Lots of slow motion
Looks like its now trying to use software decoding for hevc?
Debug log might be handy.
If software decoding is being used then you will have difficulty playing back HEVC files.
Yeah. Software decoding on h264 too, is this just a setting i can change?
If you’ve disabled hardware acceleration, you can enable it in Kodi under Settings -> Playback.
If you haven’t, then the debug log will be handy.
I haven’t touched any settings, it’s started behaving this way since the update. Unfortunately i have another vero4k working perfectly after the update, ive even compared the settings.
If you haven’t touched settings,
