Hanewin NFS autofs suddenly stopped working
I had a power out at my server and after restarting my server NFS stopped working. This configuration has been working for years.
It worked a few hours ago until I restarted my server.
here are a few logs:
sudo automount -f -v -d
Starting automounter version 5.1.2, master map /etc/auto.master
using kernel protocol version 5.03
lookup_nss_read_master: reading master file /etc/auto.master
do_init: parse(sun): init gathered global options: (null)
lookup_read_master: lookup(file): read entry +dir:/etc/auto.master.d
lookup_nss_read_master: reading master dir /etc/auto.master.d
lookup_read_master: lookup(dir): scandir: /etc/auto.master.d
lookup_read_master: lookup(file): read entry +auto.master
lookup_nss_read_master: reading master files auto.master
lookup(file): failed to read included master map auto.master
lookup_read_master: lookup(file): read entry /-
master_do_mount: mounting /-
automount_path_to_fifo: fifo name /var/run/autofs.fifo–
lookup_nss_read_map: reading map file /etc/auto.nfs.shares
mounted direct on /mnt/Anime with timeout 15, freq 4 seconds
do_mount_autofs_direct: mounted trigger /mnt/Anime
mounted direct on /mnt/Movie with timeout 15, freq 4 seconds
do_mount_autofs_direct: mounted trigger /mnt/Movie
mounted direct on /mnt/Shows with timeout 15, freq 4 seconds
do_mount_autofs_direct: mounted trigger /mnt/Shows
remount_active_mount: trying to re-connect to mount /mnt/TVshowz
mounted direct on /mnt/TVshowz with timeout 15, freq 4 seconds
remount_active_mount: re-connected to mount /mnt/TVshowz
mounted direct on /mnt/Films with timeout 15, freq 4 seconds
do_mount_autofs_direct: mounted trigger /mnt/Films
st_ready: st_ready(): state = 0 path /-
st_expire: state 1 path /-
expire_proc: exp_proc = 1946154064 path /-
expire_cleanup: got thid 1946154064 path /- stat 0
expire_cleanup: sigchld: exp 1946154064 finished, switching from 2 to 1
st_ready: st_ready(): state = 2 path /-
handle_packet: type = 5
handle_packet_missing_direct: token 12, name /mnt/Movie, request pid 1177
attempting to mount entry /mnt/Movie
lookup_mount: lookup(file): looking up /mnt/Movie
lookup_mount: lookup(file): /mnt/Movie → 192.168.1.120:/Movies
parse_mount: parse(sun): expanded entry: 192.168.1.120:/Movies
parse_mount: parse(sun): gathered options:
parse_mount: parse(sun): dequote(“192.168.1.120:/Movies”) → 192.168.1.120:/Movies
parse_mount: parse(sun): core of entry: options=, loc=192.168.1.120:/Movies
sun_mount: parse(sun): mounting root /mnt/Movie, mountpoint /mnt/Movie, what 192.168.1.120:/Movies, fstype nfs, options (null)
mount_mount: mount(nfs): root=/mnt/Movie name=/mnt/Movie what=192.168.1.120:/Movies, fstype=nfs, options=(null)
get_nfs_info: called with host 192.168.1.120(192.168.1.120) proto 6 version 0x30
expire_proc: exp_proc = 1945101392 path /-
expire_cleanup: got thid 1945101392 path /- stat 0
expire_cleanup: sigchld: exp 1945101392 finished, switching from 2 to 1
mount(nfs): no hosts available
dev_ioctl_send_fail: token = 12
failed to mount /mnt/Movie
handle_packet_missing_direct: token 13, name /mnt/Shows, request pid 1207
attempting to mount entry /mnt/Shows
lookup_mount: lookup(file): looking up /mnt/Shows
lookup_mount: lookup(file): /mnt/Shows → 192.168.1.120:/Shows
parse_mount: parse(sun): expanded entry: 192.168.1.120:/Shows
parse_mount: parse(sun): dequote(“192.168.1.120:/Shows”) → 192.168.1.120:/Shows
parse_mount: parse(sun): core of entry: options=, loc=192.168.1.120:/Shows
sun_mount: parse(sun): mounting root /mnt/Shows, mountpoint /mnt/Shows, what 192.168.1.120:/Shows, fstype nfs, options (null)
mount_mount: mount(nfs): root=/mnt/Shows name=/mnt/Shows what=192.168.1.120:/Shows, fstype=nfs, options=(null)
dev_ioctl_send_fail: token = 13
failed to mount /mnt/Shows
^Cdo_notify_state: signal 2
master_notify_state_change: sig 2 switching /- from 1 to 5
st_prepare_shutdown: state 1 path /-
expire_cleanup: sigchld: exp 1945101392 finished, switching from 5 to 7
st_shutdown: state 5 path /-
umount_multi: path /mnt/Anime incl 0
set_direct_mount_catatonic: set /mnt/Anime catatonic
umounted direct mount /mnt/Anime
umount_multi: path /mnt/Movie incl 0
set_direct_mount_catatonic: set /mnt/Movie catatonic
umounted direct mount /mnt/Movie
umount_multi: path /mnt/Shows incl 0
set_direct_mount_catatonic: set /mnt/Shows catatonic
umounted direct mount /mnt/Shows
umount_multi: path /mnt/TVshowz incl 0
do_umount_autofs_direct: ask umount returned busy for /mnt/TVshowz
set_direct_mount_catatonic: set /mnt/TVshowz catatonic
umount_multi: path /mnt/Films incl 0
set_direct_mount_catatonic: set /mnt/Films catatonic
umounted direct mount /mnt/Films
shut down path /-
trying to ls -lah a directory (none work)
ls: cannot access ‘192.168.1.120:/Shows’: No such file or directory
osmc@osmc:~$ ls -lah /mnt/Shows
ls: cannot open directory ‘/mnt/Shows’: No such file or directory
failure of starting autofs after stopping it.
sudo systemctl start autofs
Job for autofs.service failed because the service did not take the steps required by its unit configuration.
See "systemctl status autofs.service" and "journalctl -xe" for details.
osmc@osmc:~$ ^C
osmc@osmc:~$ sudo nano /etc/auto.nfs.shares
my /etc/auto.nfs.shares
GNU nano 3.2                  /etc/auto.nfs.shares
/mnt/Movie 192.168.1.120:/Movies
/mnt/Shows 192.168.1.120:/Shows
/mnt/Anime 192.168.1.120:/Anime
/mnt/Films 192.168.1.120:/Films
/mnt/TVshowz 192.168.1.120:/TVshowz
Hanewin Export
2021-01-29 01:25:50 haneWIN NFS Server 1.2.44
2021-01-29 01:25:50 Unregistered version, for up to 30 days evaluation only
2021-01-29 01:25:50 nfsd file handle cache size 24
2021-01-29 01:25:50 nfsd client charset UTF-8
2021-01-29 01:25:50 nfsd maximum data size 65536
2021-01-29 01:25:50 nfsd NTFS hardlinks supported
------ Exported file systems ------
T:\Shows -name:Shows -readonly 192.168.1.114 192.168.1.116
V:\Movie -name:Movies -readonly 192.168.1.114 192.168.1.116
R:\Anime -name:Anime -readonly 192.168.1.114 192.168.1.116
U:\Movies -name:Films -readonly 192.168.1.114 192.168.1.116
M:\Moviez -name:Moviez -readonly 192.168.1.114 192.168.1.116
M:\TVshowz -name:TVshowz -readonly 192.168.1.114 192.168.1.116
2021-01-29 01:25:50 mountd started on 1058
2021-01-29 01:25:50 nfsd started on 2049, 4 udp threads
2021-01-29 01:25:50 nlmd started on 4045
2021-01-29 01:25:50 Unregistered version expired!
Please register the software
(I know the trial is up but never had issues with it),
Can someone help me please? I have no idea what else to do.
I restarted my Hanewin on my server end, closed the nfsd and restarted, port mapper, and restarted. The portmapper sows up as everything is working, the export and mount section is empty, while in the start menu of Hanewin it shows all my 6 entries, when I click exports I get this:
# exports example
# please read doc for a list of all options
# drive letters should be in upper case, because file-id returns upper case
#   by default (option setting) they are mapped to lower case for clients
# Option -range restricts access to specified address range
#   a list of addresses restricts to these clients only
# Option -readonly prohibits create/write/delete
# Option -name:<x> makes folder for clients avalailable as /<x>
# Option -maproot:<uid> maps unix root to specified <uid>
#   without it uid root -> uid NOBODY
# Option -alldirs allows clients to mount folder or any subfolder
# Use UNC path specification for access to remote drive
# Hidden volumes without a drive letter can be mounted by volume GUID
#C:\ftp -range 192.168.1.1 192.168.1.10
#C:\video -readonly 192.168.1.1 192.168.1.4 192.18.1.23
#C:\server -alldirs -name:server -maproot:0 -range 192.168.1.1 192.168.1.30
#\\router\FRITZ.NAS\SanDisk-U3CruzerMicro-00 -name:fritz
#\\?\Volume{6afa3aa3-1b38-11e6-a140-0000fbaa0005}\ -name:drive1
t:\Shows -name:Shows -readonly 192.168.1.114 192.168.1.116
v:\Movie -name:Movies -readonly 192.168.1.114 192.168.1.116
r:\Anime -name:Anime -readonly 192.168.1.114 192.168.1.116
u:\Movies -name:Films -readonly 192.168.1.114 192.168.1.116
I have no idea whats wrong, same results on Pi3 and vero4k, never had issues before.
Can someone please help me?
Seems to fixed itself updating to the latest hanewin Networking Software for Windows v1.2.56, very strange.
Are you sure that the IP of the server didn’t change?
Something similar happened to me the other day. Reinstalling the latest version of Hanewin fixed it.
Having said that, there have been some major speed improvements to accessing SMB via autofs recently - that’s now so fast I no longer need to use Hanewin.
