hi guys, someone could tell me what will happens if i remove the hard disk and put a fresh new hard disk on apple tv1? the osmc is removed and appletv1 original os will be restored? i has this doubt before to replace the hs by ssd.
Your disk will be blank.
Don’t bother investing in an SSD for 10-year old hardware with a PATA interface. Just get some better hardware if you want better performance.
Some users may be able to comment on which SSDs work.
