Hi, I had to buy the powered 4 port USB hub, because whenever I tried to play a high bitrate 4K HDR with Dolby TrueHD, the system would collapse and restart. Presumably due to the lack of power to the drive.
My issue however, is that when I connect the hub to the Vero 4k+, turn on the switch to the port so that it lights blue, and connect my hard drive, the hard drive no longer is recognized inside osmo / the OS. What do I need to do in order for it to be able to see my hard drive again? It works just fine when I connect it directly to the Vero 4k, just not through the hub.
Best regards.
reproduce the issue
Try a different port and make sure the switch is on.
