Hi Guys,
I’m going to buy a new raspberry pi model B (v2).
If I plugin in this one my SD card from my previous one (v1).
It will work correctly ?
Thanks for help.
Hi Guys,
Thanks for help.
I don’t think the SD card for RPi v1 will work with RPi v2.
However, maybe you can export most of your settings on your v1 RPI?
After creating an image for your v2 RPi, you can import the files back into OSMC.
.Nico
You will need a fresh install
The OSMC backup utility may help you here
Thanks Sam for your answer and nico too.
My OSMC backup is ready !
