Hi, I was wondering if there are any improvements planned for the Vero 4k hardware-wise, one candidate is for instance the optical port…
I remember @sam_nazarko saying there weren’t any HW updates planned in the near future which I can understand; the box supports 4K, HD-audio, HDR so everything which is “mainstream” at the moment.
What improvement are you looking for (in the optical port)?
I’d like to see an improvement of the optical port; I somehow destroyed it without recognizing the 1st time I used it
Did you try repairing it following my instructions? It was fairly simple and stable afterwards…
nope, not yet. It works somehow and I fear to destroy the port during repair
I can’t guarantee anything, but from my experience, the port should be the last thing you can destroy during the repair process. More likely you could break the new flap
But it’s up to you…
The reports of the flap breaking are very rare and, TBH, it was not “normal” use which broke it, but some stupidity on my side.
Under normal use it should be quite fine.
The door is pretty strong – as long as you remove it at a straight angle and not diagonally it will not break.
