mk150
15 September 2018 06:27
1
Hi folks,
I recently got a Vero 4K+ and I’ve paired it to my Harmony Elite using Bluetooth, which seems to work fairly well.
I’m trying to fine tune the key mappings on a few things to do what I want.
Is there a Windows key mapping for Suspend? I’d like to suspend the device when I switch everything on, and wake it up when I switch to it.
Most likely Keymap Editor will enable you to do what you want.
https://kodi.wiki/view/Add-on:Keymap_Editor
This sounds confusing, why would you want to suspend the device when you switch everything on?
Or you mean when you switch everything off?
I have configured (CEC setting) that the Vero goes to Suspend when I switch off the TV. It will come out of suspend as soon as you press any remote button.
mk150
15 September 2018 06:55
3
Gah, I got that backward, I meant I want to suspend it when I switch everything off.
Than try Settings - System - Input - Peripherals - CEC Adapter - “When the TV is switched off - Suspend”
mk150
15 September 2018 07:10
5
That did the trick, thanks!
FWIW, it’d be nice if the “when switch to another input” also had a ‘Suspend’ option. But TV off works well enough.
