I tried to connect a new Hauppage WinTV dualHD tuner to my Vero 4K+ but in tvheadend no adapters are shown.
From what I can see in dmesg the device seems to be identified correctly:
[92390.737003] usb 1-1: new high-speed USB device number 23 using xhci-hcd
[92390.907842] usb 1-1: New USB device found, idVendor=2040, idProduct=0265
[92390.907850] usb 1-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[92390.907854] usb 1-1: Product: dualHD
[92390.907858] usb 1-1: Manufacturer: HCW
[92390.907861] usb 1-1: SerialNumber: 0014316376
[92390.927815] em28xx: New device HCW dualHD @ 480 Mbps (2040:0265, interface 0, class 0)
[92390.927822] em28xx: DVB interface 0 found: isoc
[92390.997094] em28xx: chip ID is em28174
[92392.313351] em28174 #0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x05e2cac8
[92392.313357] em28174 #0: EEPROM info:
[92392.313360] em28174 #0: microcode start address = 0x0004, boot configuration = 0x01
[92392.319523] em28174 #0: AC97 audio (5 sample rates)
[92392.319528] em28174 #0: 500mA max power
[92392.319533] em28174 #0: Table at offset 0x27, strings=0x0e6a, 0x1888, 0x087e
[92392.386938] em28174 #0: Identified as Hauppauge WinTV-dualHD DVB (card=99)
[92392.393907] tveeprom 1-0050: Hauppauge model 204109, rev C3I6, serial# 14316376
[92392.393915] tveeprom 1-0050: tuner model is SiLabs Si2157 (idx 186, type 4)
[92392.393919] tveeprom 1-0050: TV standards PAL(B/G) NTSC(M) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xfc)
[92392.393923] tveeprom 1-0050: audio processor is None (idx 0)
[92392.393926] tveeprom 1-0050: has no radio, has IR receiver, has no IR transmitter
[92392.393932] em28174 #0: dvb set to isoc mode.
[92392.457039] em28xx: chip ID is em28174
[92393.763471] em28174 #1: EEPROM ID = 26 00 01 00, EEPROM hash = 0x05e2cac8
[92393.763477] em28174 #1: EEPROM info:
[92393.763480] em28174 #1: microcode start address = 0x0004, boot configuration = 0x01
[92393.769562] em28174 #1: AC97 audio (5 sample rates)
[92393.769568] em28174 #1: 500mA max power
[92393.769572] em28174 #1: Table at offset 0x27, strings=0x0e6a, 0x1888, 0x087e
[92393.836921] em28174 #1: Identified as Hauppauge WinTV-dualHD DVB (card=99)
[92393.842970] tveeprom 3-0050: Hauppauge model 204109, rev C3I6, serial# 14316376
[92393.842978] tveeprom 3-0050: tuner model is SiLabs Si2157 (idx 186, type 4)
[92393.842982] tveeprom 3-0050: TV standards PAL(B/G) NTSC(M) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xfc)
[92393.842986] tveeprom 3-0050: audio processor is None (idx 0)
[92393.842989] tveeprom 3-0050: has no radio, has IR receiver, has no IR transmitter
[92393.842995] em28174 #0: dvb ts2 set to isoc mode.
[92394.044973] em28174 #0: Binding DVB extension
[92394.054102] em28174 #1: Binding DVB extension
[92394.063147] em28174 #0: Registering input extension
[92394.063349] Registered IR keymap rc-hauppauge
[92394.063672] input: em28xx IR (em28174 #0) as /devices/platform/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1/input22
[92394.063943] rc rc1: em28xx IR (em28174 #0) as /devices/platform/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1
[92394.064142] em28174 #0: Input extension successfully initalized
[92394.064148] em28174 #1: Remote control support is not available for this card.
I found some post on the WinTV dualHD on the forum, but no real solution. Also I couldn’t really make sure, if the device is supported on the Vero 4K+ by now or not (it should be since kernel 4.7, I think).
Any ideas?
