Hi All,
I need help for configure my raspberry with dvb-t, i have already reinstalled driver but when i try scan channels the result is ever 0 channel. I try with last version of the osmc but same result.
Very thanks
Below the detail.
Hardware : Raspberry pi 2
uname : osmc@osmc:~$ uname -r
3.18.13-1-osmc
DVB-t : Hauppauge WinTV HVR-900H
Driver : xc3028L-v36.fw.
[ 880.870330] usb 1-1.3: new high-speed USB device number 8 using dwc_otg
[ 880.976239] usb 1-1.3: New USB device found, idVendor=2040, idProduct=6600
[ 880.976272] usb 1-1.3: New USB device strings: Mfr=16, Product=32, SerialNumber=64
[ 880.976288] usb 1-1.3: Product: HVR900H
[ 880.976304] usb 1-1.3: SerialNumber: 4032036625
[ 880.984584] tm6000: alt 0, interface 0, class 255
[ 880.984609] tm6000: alt 0, interface 0, class 255
[ 880.984624] tm6000: Bulk IN endpoint: 0x82 (max size=512 bytes)
[ 880.984636] tm6000: alt 0, interface 0, class 255
[ 880.984648] tm6000: alt 1, interface 0, class 255
[ 880.984661] tm6000: ISOC IN endpoint: 0x81 (max size=3072 bytes)
[ 880.984672] tm6000: alt 1, interface 0, class 255
[ 880.984684] tm6000: alt 1, interface 0, class 255
[ 880.984697] tm6000: INT IN endpoint: 0x83 (max size=4 bytes)
[ 880.984708] tm6000: alt 2, interface 0, class 255
[ 880.984720] tm6000: alt 2, interface 0, class 255
[ 880.984732] tm6000: alt 2, interface 0, class 255
[ 880.984744] tm6000: alt 3, interface 0, class 255
[ 880.984755] tm6000: alt 3, interface 0, class 255
[ 880.984767] tm6000: alt 3, interface 0, class 255
[ 880.984781] tm6000: New video device @ 480 Mbps (2040:6600, ifnum 0)
[ 880.984792] tm6000: Found Hauppauge WinTV HVR-900H / WinTV USB2-Stick
[ 880.985361] Found tm6010
[ 881.431558] tm6000 #0: i2c eeprom 00: 01 59 54 45 12 01 00 02 00 00 00 40 40 20 00 66 .YTE…@@ .f
[ 881.449871] tm6000 #0: i2c eeprom 10: 69 00 10 20 40 01 02 03 48 00 79 00 62 00 72 00 i… @…H.y.b.r.
[ 881.468025] tm6000 #0: i2c eeprom 20: ff 00 64 ff ff ff ff ff ff ff ff ff ff ff ff ff …d…
[ 881.486737] tm6000 #0: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.505538] tm6000 #0: i2c eeprom 40: 10 03 48 00 56 00 52 00 39 00 30 00 30 00 48 00 …H.V.R.9.0.0.H.
[ 881.524069] tm6000 #0: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.542384] tm6000 #0: i2c eeprom 60: 30 ff ff ff 0f ff ff ff ff ff 0a 03 32 00 2e 00 0…2…
[ 881.560747] tm6000 #0: i2c eeprom 70: 3f 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ?..
[ 881.579122] tm6000 #0: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.597525] tm6000 #0: i2c eeprom 90: 33 ff ff ff 16 03 34 00 30 00 33 00 32 00 30 00 3…4.0.3.2.0.
[ 881.615758] tm6000 #0: i2c eeprom a0: 33 00 36 00 36 00 32 00 35 00 00 00 00 00 ff ff 3.6.6.2.5…
[ 881.633976] tm6000 #0: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.652404] tm6000 #0: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.670624] tm6000 #0: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.689149] tm6000 #0: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.707426] tm6000 #0: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
[ 881.731427] tuner 0-0061: Tuner -1 found with type(s) Radio TV.
[ 881.731580] xc2028 0-0061: creating new instance
[ 881.731600] xc2028 0-0061: type set to XCeive xc2028/xc3028 tuner
[ 881.731614] Setting firmware parameters for xc2028
[ 881.731971] usb 1-1.3: Direct firmware load for xc3028L-v36.fw failed with error -2
[ 881.731996] xc2028 0-0061: Could not load firmware xc3028L-v36.fw.
[ 881.732161] tm6000 #0: registered device video0
[ 881.732176] Trident TVMaster TM5600/TM6000/TM6010 USB2 board (Load status: 0)
[ 881.734284] DVB: registering new adapter (Trident TVMaster 6000 DVB-T)
[ 881.734318] usb 1-1.3: DVB: registering adapter 0 frontend 0 (Zarlink ZL10353 DVB-T)…
[ 881.734671] xc2028 0-0061: attaching existing instance
[ 881.734688] xc2028 0-0061: type set to XCeive xc2028/xc3028 tuner
[ 881.734699] tm6000: XC2028/3028 asked to be attached to frontend!
[ 881.860380] Registered IR keymap rc-hauppauge
[ 881.861202] input: tm5600/60x0 IR (tm6000 #0) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/rc/rc0/input5
[ 881.861607] rc0: tm5600/60x0 IR (tm6000 #0) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/rc/rc0
[ 882.244666] tm6000: IR URB failure: status: -2, length 0
