Good day team!
Noticed after watching a movie that was HDR seemed very dark and also had the same movie with no HDR and was quite different (brighter)
Same movie, similar file size (~30gb) one is HDR one is not. Both appear to be 10bit.
HDR file is very grey and flat, non-hdr file much more colorful and bright.,
I have a Sony XBR75X900E & Denon AVR-X2300W
Adjust Refresh rate is set to Always, and gui is at 1080p
I know in the last year there were a lot of improvements done with this on the Vero 4k, so if there are issues like this, are we thinking it might be due to poor encoding?
I have a bunch of comparison info i did on both files, as well as my equipment which is 4K and HDR compliant and new 2.0 hdmi cables.
/media$ cat /sys/class/amhdmitx/amhdmitx0/edid
Rx Brand Name: DON
Rx Product Name: DENON-AVR
Manufacture Week: 0
Manufacture Year: 2016
Physical size(cm): 166 x 93
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0x47
Source Physical Address[a.b.c.d]: 3.5.0.0
YCC support 0x03, VIC (native 255):
ColorDeepSupport 0xb8 10/12/16/Y444 1/1/0/1
97 96 93 94 95 98 31 16 20 5 19 4 32 34 60 62 18 22 3 7 17 21 2 6 1 101 102 14 35 15 36 95 94 93 98 353 352 357 358
Audio {format, channel, freq, cce}
{1, 7, 0x7f, 0x07}
{7, 5, 0x1e, 0x00}
{2, 5, 0x07, 0x00}
{11, 7, 0x7e, 0x03}
{10, 7, 0x06, 0x03}
{12, 7, 0x7e, 0x03}
{11, 7, 0x7e, 0x01}
Speaker Allocation: 0x5f
Vendor: 0x000c03
MaxTMDSClock1 300 MHz
Vendor2: 0xc45dd8
MaxTMDSClock2 600 MHz
Colorimetry: 0xdf
SCDC: 1
RR_Cap: 0
LTE_340M_Scramble: 0
HDR DeepColor
checkvalue: 0x477f0000
cat /sys/class/amhdmitx/amhdmitx0/disp_cap
480p60hz
576p50hz
720p50hz
720p60hz
1080p24hz
1080p30hz
1080i50hz
1080p50hz
1080i60hz
1080p60hz
2160p24hz
2160p25hz
2160p30hz
2160p50hz
2160p50hz420
2160p60hz
2160p60hz420
smpte24hz
smpte50hz
smpte50hz420
smpte60hz
smpte60hz420
HDR FILE
/media$ cat /sys/class/amhdmitx/amhdmitx0/config
AVIF VIC: 0
VIC: 93 3840x2160p24hz
Colour depth: 10-bit
Colourspace: YUV444
Colour range: limited
EOTF: HDR10
YCC colour range: limited
PLL clock: 0xc000029a, Vid clock div 0x000b0000
Aspect ratio: 16:9/full frame
Audio config: on
3D config: off
Non HDR file - same movie
AVIF VIC: 0
Colour depth: 10-bit <–Curious that OSMC gui shows it as 8 bit, but this command reports 10
Colourspace: YUV444
EOTF: SDR
Audio config: on
3D config: off
NON HDR Mediainfo:
Video
Format : HEVC
Format profile : Main 10@L5@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 3 h 1 min
Bit rate : 24.2 Mb/s
Width : 3 840 pixels
Height : 1 608 pixels
Original height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.163
Stream size : 30.7 GiB (95%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
HDR file Mediainfo
Video
Format : HEVC
Commercial name : HDR10
Bit rate : 23.9 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.162
Stream size : 30.4 GiB (95%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0020 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1011 cd/m2
Maximum Frame-Average Light Level : 592 cd/m2
Thanks.
