Here is what I did watching a movie from my private library stopped it went to HDhomerun clicked on ABC channel would not play ![]()
Log
https://paste.kodi.tv/oxevuroqiq
WOW nothing ?
2021-03-18 08:14:32.619 T:4064649232 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/All channels/pvr.hdhomerun_935522772.pvr
2021-03-18 08:14:32.620 T:3962745056 NOTICE: Creating InputStream
2021-03-18 08:14:33.857 T:3962745056 ERROR: Open - Unhandled exception
2021-03-18 08:14:33.858 T:3962745056 ERROR: Open - Error opening http://10.0.0.10:5004/auto/v1027
2021-03-18 08:14:33.858 T:3962745056 ERROR: CVideoPlayer::OpenInputStream - error opening [pvr://channels/tv/All channels/pvr.hdhomerun_935522772.pvr]
Has IP address of hdhomerun changed?
Can you access http://10.0.0.10:5004/auto/v1027 from VLC or another computer?
IP is still the same. This isnt the first time my VERO+ might not have many frown crashes but it does freeze up alot so I have to reboot.
Do you have a support request open for this?
If you’ve experienced problems in the past it would be good to work out why and solve them. The issues may be related.
Which HDHomerun Add-on are you using?
Running Vero 4K here. Using the one from SiliconDust - 2019.9.15 and all’s working well.
Well if you go here https://kodi.tv/addon/scripts-video-add-ons/hdhomerun
the direct Zip function does not work
I always put the zip file on my server so the other KODI boxes can access it easy.
