This morning I update OSMC to new update. I want to submit to this community a problem I experienced today (this is not first time). I have my WD 1 Terabyte HD mounted under /media/KODI.
I started KODI this morning and saw the update message, so I decided to update it.
After upgrade the OSMC system crashed.
After reboot I had few new Movies and I decided to scrapes the title and fanart with MovieDB plugin.
I started the Update library but this ended quickly.
Looking at kodi.log I noticed that my movie folder was not reachable anymore.
So I checked the filesystem and I noticed that my HD was mounted under /media/KODI_ and /media/KODI was empty obviously.
My fix was to umount /media/KODI_, immediately the folder itself was removed and I removed the /media/KODI folder so that next restart the OSMC automatic remount created it again (I already did it in the past). This fix solved the problem.
The question is: why this occurred? Is this a scenario not covered by OSMC tests?
I am not waiting for an answer, for me is ok my fix. This message is just to let the community aware of this problem I found.
