Hi. Shouldn’t the Vero put the HDD to sleep after 15 minutes after going on suspend? Using the 2019.05-1 update. Worried because my cables are hot.
I would check for any addons that may be accessing the drive.
The USB cable? Something does not sound right at all. I’ve never felt a hot USB cable.
I’ll do that. Thanks, @bmillham!
No 3rd party add ons. Just what’s in the default of Vero.
@bmillham
I’m wrong. Very sorry. I meant the connector is hot. Not the cable itself. I now think that sleep for hdd is working because hdd lags 1st time I use it after suspend. Is the connector being hot normal?
Yes, it is.
Thanks @TheHacker66
Drives will spin down after:
- 15 minutes of inactivity, if and only if the caddy supports the command we send to do this.
- The disk is truly inactive, i.e. there are no open files
Thanks , @sam_nazarko
