HDHomerun problems
I purchased a VERO 4K couple of months ago
If I leave it on and turn off the TV at night the next morning the guide is still on the same hour when I use the back key and go back to the guide its still the same can do this several times the only way I can correct it is reboot.
Anyone else have this same issue ?
I think this is a KODI function.
When you navigate to Settings --> PVR & Live TV --> Guide you will have a setting that allows you to change the past days to display. If you set that to zero, the guide will stay current on what is playing unless you travel forward and have not reached that time yet.
