Have Pi 3b+ running latest OSMC connected to a TCL android TV.
Really struggling to keep the HDMI alive. Added the following to config:
hdmi_mode=16
hdmi_force_hotplug=1
config_hdmi_boost=7
hdmi_group=1
hmdi_drive=2
And now if TV is put in standby when it is turned back on, the signal is there. However if TV is off (or in standby) when PI/ OSMC boots there is no signal when I turn TV on.
Any ideas - very flaky power in this house causes numerous power outs, so this is a common problem for me
@sam_nazarko thanks for the reply. Can you give me any pointers how to do this? Searched the forum but can only find d one post about a similar issue in the veto with the command:
@sam_nazarko Indeed possible. So far I read itâs an alternative but doesnât seems mandatory. Curious to see if such impact or not config_txt reference
@getyogg
Something to try: as en edid file is provided, may you comment the below lines in your config.txt file and reboot? (with the edid still defined as in my previous post). It may conflict with the edid info
hdmi_mode=16
hdmi_group=1
And I see @grahamh post during my post writing, some testing needed
Indeed. When I looked, the RPi docs were not clear about which options and commands still apply in the KMS world. I was concentrating on getting Pi to boot without a display attached and canât remember if I eventually got a picture after attaching a display after a headless boot. Some lines in config.txt may be needed.
I have tried your suggestion but in /sys/devices/platform I do not have a folder âgpuâ. Having searched for EDID in the platform folder I have found it located at:
