I had a corrupted SD card so I had to reinstall OSMC to a new card. RaspberryPI2 B with 1G of RAM.
Initially everything was working fine (well, I had to reconfigure everything), but once I just realized that the remote doesn’t work as it used to. And it worked initially with the new system also. But now it stopped working with TV. It’s a Samsung.
On the TV the Anynet+ is enabled, but when I go to find devices it doesn’t find any.
It worked, but now it doesn’t work…
Debug logs can be found here:
https://paste.osmc.tv/sodalamusi
Could it be that I have enabled a tty console also (so when mediacenter service is stopped I got a text console on screen, instead of rebooting kodi)?
When kodi is not running the cec-client’s outputs this:
osmc@osmc:~/.kodi/temp$ cec-client
No device type given. Using 'recording device'
CEC Parser created - libCEC version 6.0.2
no serial port given. trying autodetect:
path: /dev/cec0
com port: Linux
opening a connection to the CEC adapter...
DEBUG: [ 97] Broadcast (F): osd name set to 'Broadcast'
DEBUG: [ 97] CLinuxCECAdapterCommunication::Open - m_fd=3 bStartListening=1
DEBUG: [ 97] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_G_PHYS_ADDR - addr=2000
DEBUG: [ 97] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 98] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=8000 num_log_addrs=1
NOTICE: [ 98] connection opened
DEBUG: [ 98] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=8000 phys_addr=2000
DEBUG: [ 99] << Broadcast (F) -> TV (0): POLL
TRAFFIC: [ 99] << f0
DEBUG: [ 99] processor thread started
DEBUG: [ 404] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=1 addr=f0 opcode=ffffffff
DEBUG: [ 404] >> POLL sent
DEBUG: [ 404] TV (0): device status changed into 'present'
DEBUG: [ 404] << requesting vendor ID of 'TV' (0)
TRAFFIC: [ 404] << f0:8c
DEBUG: [ 471] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=f0 opcode=8c
DEBUG: [ 1471] expected response not received (87: device vendor id)
TRAFFIC: [ 1472] << f0:8c
DEBUG: [ 1524] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=f0 opcode=8c
DEBUG: [ 2525] expected response not received (87: device vendor id)
DEBUG: [ 2525] registering new CEC client - v6.0.2
DEBUG: [ 2525] SetClientVersion - using client version '6.0.2'
NOTICE: [ 2525] setting HDMI port to 1 on device TV (0)
DEBUG: [ 2525] SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
DEBUG: [ 2525] detecting logical address for type 'recording device'
DEBUG: [ 2525] trying logical address 'Recorder 1'
DEBUG: [ 2525] << Recorder 1 (1) -> Recorder 1 (1): POLL
TRAFFIC: [ 2525] << 11
DEBUG: [ 2587] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=11 opcode=ffffffff
TRAFFIC: [ 2588] << 11
DEBUG: [ 2659] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=11 opcode=ffffffff
DEBUG: [ 2659] >> POLL not sent
DEBUG: [ 2659] using logical address 'Recorder 1'
DEBUG: [ 2659] Recorder 1 (1): device status changed into 'handled by libCEC'
DEBUG: [ 2659] Recorder 1 (1): power status changed from 'unknown' to 'on'
DEBUG: [ 2659] Recorder 1 (1): vendor = Pulse Eight (001582)
DEBUG: [ 2659] Recorder 1 (1): CEC version 1.4
DEBUG: [ 2659] AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
DEBUG: [ 2659] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 2660] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=2000
DEBUG: [ 2802] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0002 phys_addr=2000
DEBUG: [ 2802] changing physical address to 2000
DEBUG: [ 2802] Recorder 1 (1): physical address changed from ffff to 2000
DEBUG: [ 2802] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0002 num_log_addrs=1
DEBUG: [ 2802] Recorder 1 (1): osd name set to 'CECTester'
DEBUG: [ 2802] Recorder 1 (1): menu language set to 'eng'
DEBUG: [ 2802] using provided physical address 2000
NOTICE: [ 2802] CEC client registered: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 0, logical address(es) = Recorder 1 (1) , physical address: 2.0.0.0, compiled on 2021-02-21 00:19:23 by root@compiler2 on Linux 4.19.0-9-amd64 (armv7l), features: P8_USB, DRM, P8_detect, Linux
DEBUG: [ 2802] << Recorder 1 (1) -> TV (0): OSD name 'CECTester'
TRAFFIC: [ 2802] << 10:47:43:45:43:54:65:73:74:65:72
DEBUG: [ 3358] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=11 addr=10 opcode=47
DEBUG: [ 3358] << requesting power status of 'TV' (0)
TRAFFIC: [ 3358] << 10:8f
DEBUG: [ 3425] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=10 opcode=8f
DEBUG: [ 4425] expected response not received (90: report power status)
TRAFFIC: [ 4425] << 10:8f
DEBUG: [ 4478] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=01 len=2 addr=10 opcode=8f
waiting for input
DEBUG: [ 5478] expected response not received (90: report power status)
^Csignal caught: 2 - exiting
DEBUG: [ 32931] unregistering all CEC clients
NOTICE: [ 32931] unregistering client: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 0, logical address(es) = Recorder 1 (1) , physical address: 2.0.0.0, compiled on 2021-02-21 00:19:23 by root@compiler2 on Linux 4.19.0-9-amd64 (armv7l), features: P8_USB, DRM, P8_detect, Linux
DEBUG: [ 32931] Recorder 1 (1): power status changed from 'on' to 'unknown'
DEBUG: [ 32931] Recorder 1 (1): vendor = Unknown (000000)
DEBUG: [ 32931] Recorder 1 (1): CEC version unknown
DEBUG: [ 32931] Recorder 1 (1): osd name set to 'Recorder 1'
DEBUG: [ 32931] Recorder 1 (1): device status changed into 'unknown'
DEBUG: [ 32931] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=2000
DEBUG: [ 32931] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 32936] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=2000
DEBUG: [ 33943] CLinuxCECAdapterCommunication::Process - stopped - m_fd=3
DEBUG: [ 33943] CLinuxCECAdapterCommunication::Close - m_fd=3
Could someone guide me to the correct direction where to look because now I am clueless…
Thanks,
S
