If , at startup, the HDMI cable is not properly plugged into the device or in the monitor and plugging it after, wont make it work, I have to switch off the device, replug the cable and reboot the device.
Is this normal?
If so, is there a way to make the device detect the HDMI after the boot?
With the HDMI Cable connected and the right picture shown. Connect via ssh and run sudo tvservice -d /boot/edid.dat
Afterwards go to MyOSMC - Pi Config - Display and activate hdmi_edid_file
Worked perfectly,
Thank you!
