Unfortunately without a Cinema Display at hand, it’s really hard for me to generate a good, valid modeline for this device. I will see what I can do, but I am not certain that we can get a 1920x1200 mode without having this monitor at hand to test.
In the interim, with the new kernel, it would be good to see if the new mode that I added is at least being selected by the kernel.
Not sure – if you are defining a hdmi_mode in config.txt, then it’s being explicitly forced, and the EDID is ignored. I’m not sure why you have to use hdmi_safemode though…
It is hard for me to assess the problem without the monitor or adapter at hand
Extracted contents:
header: 00 ff ff ff ff ff ff 00
serial number: 34 90 60 10 00 00 00 00 2a 13
version: 01 03
basic params: 80 3c 22 78 2a
chroma info: 03 20 a7 55 45 96 24 11 49 4b
established: 00 00 00
standard: d1 00 81 c0 01 01 01 01 01 01 01 01 01 01 01 01
descriptor 1: 28 3c 80 a0 70 b0 23 40 30 20 36 00 07 44 21 00 00 1a
descriptor 2: 01 1d 00 72 51 d0 1e 20 6e 28 55 00 c4 8e 21 00 00 1e
descriptor 3: 00 00 00 fc 00 4d 44 50 20 41 64 61 70 74 65 72 0a 20
descriptor 4: 00 00 00 fd 00 30 4b 0b 96 14 00 0a 20 20 20 20 20 20
extensions: 01
checksum: d2
Manufacturer: MDP Model 1060 Serial Number 0
Made week 42 of 2009
EDID version: 1.3
Digital display
Maximum image size: 60 cm x 34 cm
Gamma: 2.20
DPMS levels: Off
Supported color formats: RGB 4:4:4, YCrCb 4:2:2
First detailed timing is preferred timing
Established timings supported:
Standard timings supported:
1920x1200@60Hz
1280x720@60Hz
Detailed mode: Clock 154.000 MHz, 519 mm x 324 mm
1920 1968 2000 2080 hborder 0
1200 1203 1209 1235 vborder 0
+hsync -vsync
Detailed mode: Clock 74.250 MHz, 708 mm x 398 mm
1280 1390 1430 1650 hborder 0
720 725 730 750 vborder 0
+hsync +vsync
Monitor name: MDP
Monitor ranges (GTF): 48-75Hz V, 11-150kHz H, max dotclock 200MHz
Has 1 extension blocks
Checksum: 0xd2 (valid)
CEA extension block
Extension version: 3
31 bytes of CEA data
Video data block
VIC 04 1280x720@60Hz (native)
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
VIC 00 Unknown mode
Audio data block
Linear PCM, max channels 1
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
Vendor-specific data block, OUI 000c03 (HDMI)
Source physical address 1.0.0.0
Unknown tag 0, length 0 (raw 00)
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
1 native detailed modes
+hsync +vsync
+hsync +vsync
+hsync +vsync
Detailed mode: Clock 74.250 MHz, 603 mm x 342 mm
-hsync -vsync analog composite
Checksum: 0xe7 (valid)
EDID block does NOT conform to EDID 1.3!
Detailed block string not properly terminated
I can try and work with this. The monitor seems to advertise that it supports 720p VIC Mode 4, so I am not sure why you cannot get a picture with the 720p mode which is already baked in to the kernel. It would probably be good to see if we can get that working first.
If you set hdmi_mode=4 on your Pi, do you get a 720p image?
This seems to suggest that the screen is advertising 720p and 1200p, even though 720p does not work for your display. Weirdly, it seems to advertise the 720p as the preferred / native CEA Mode.
I have generated a 1200p modeline but my suspicion is that the reason it’s not working may be because the monitor or adapter are not reporting the correct supported settings.
Last thing I can think of is maybe you need hdmi_mode=19 (720p50), but it is advertising a preferred mode of 720p60…
