I keep the vero 4k+ running all the time and just switch off the tv in the evening.
The next day I turn the tv on again but then the HDMI signal is lost!?
The vero 4k+ is still running when I access it via the KODI app and after a reboot it is fixed but I wonder if there is any standby happening?
I already switched on “Lock HDMI HPD” enabled but doesn`t make a difference.
I uploaded all the logs after it went black, but had to reboot as I used the MyOsmc loguploader (as I don’t know where to collect them in the ssh console?!)
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
hi everyone!
it happened to me, also
please try change the HDMI cable - it was my solution, at least
received the box with August firmware, everything was OK, but after the October update the problems start to rise: blank screen for any 4K video
after changing the cable all went as before, no problem whatsoever
thanks all. I enabled the debugging and actually reverted back the apple 4k screensaver to NONE.
actually now it is working as it is always on since 1 day. finger crossed that this was the issue…
