I have the standard Vero 4k and will be replacing my old projector with a new Epson 4k projector. Has anyone had any success using a HDMI splitter to feed the video to the projector and the audio to my AV amp.
Any tips would be appreciated.
Thanks.
It will work - if you use a good splitter. I’ve used an HDFury Vertex in the past for this – although this is probably overkill for your requirements.
Thank you Sam I will have a look around for something similar.
HDFury AVRKey or Egreat H10 might be suitable.
Thank you very much the HD Fury looks like a good choice.
