Hi all
I’m new here and about to buy a vero 4k+.
Til now I’m using a Zotac Nano with libreelec, connected to a hdmi switch. there is also a ps4 connected to this hdmi switch.
this switch autoselects the right input if a device is powered on. Now i read that the vero is an always on device. If this is the case I have to manually switch the input if I want to play on my ps4.
is here someone else having a similar setup? how can I bypass this?
If you select “suspend” on the Vero it will disable the HDMI port which should be identical to your HDMI switch to it been switched off
ok thank you!
