Before the update i had no problems with HDR,after setttng below config.
osmc@osmc-Ignatius:~$ cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
echo '444,10bit' > /sys/class/amhdmitx/amhdmitx0/attr
exit 0
My config is still as above.
My TV has stopped detecting the signal as HDR. Has anyone had the same problem ?
Jan 19 16:15:48 osmc-Ignatius systemd[1]: Starting /etc/rc.local Compatibility…
Jan 19 16:15:48 osmc-Ignatius systemd[1]: Started /etc/rc.local Compatibility.
Warning: rc-local.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.
Seems i need to reload it.
After reloading and rebooting, it still didn’t work and still returns the warning:
osmc@osmc-Ignatius:~$ systemctl status rc.local
rc-local.service - /etc/rc.local Compatibility
Loaded: loaded (/lib/systemd/system/rc-local.service; static; vendor preset: enabled)
Drop-In: /lib/systemd/system/rc-local.service.d
`-debian.conf
Active: active (exited) since Sat 2018-01-20 14:43:34 CET; 6min ago
Process: 413 ExecStart=/etc/rc.local start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/rc-local.service
Jan 20 14:43:34 osmc-Ignatius systemd[1]: Starting /etc/rc.local Compatibility…
Jan 20 14:43:34 osmc-Ignatius systemd[1]: Started /etc/rc.local Compatibility.
osmc@osmc-Ignatius:~$ cat /sys/class/amhdmitx/amhdmitx0/attr 444,10bit
This seems to suggest everything is as it’s supposed to.
The reciever does seem to see the 10 bit signal. The HDR indication seems to disappear.
Was there a new option to enable HDR in the ui in the new version? I havn’t been able to find it.
