Turns out round1 solved my banding issue. Still visible from a foot away but much narrower bands so it looks like a perfect gradient from 10 feet away. Thanks for the help with the callbacks configuration folks!
Edit-round1 was the fix for me to my Visio panel. Edited from round0 to round1 above.
One last question on the callbacks configuration. I’m just putting in the one line command vs the scrip that was posted earlier with the sleep variable. Should I use the script?
Mule seems to think it is but I havent tested myself. I had it previously as it takes some time to initialize video but don’t know if it affects the dither setting. Have you tried just the line?
Yes, I’m currently using just the line directly in the callbacks command field. Seems to work just fine. There is always a 500ms or so delay related to the resolution change anyway so I don’t think it is entirely necessary for my setup. It definitely cleaned up the gradient changes in scenes with sky and clouds like in Oblivion 4K UHD rip. I’m definitely happy even if this is a bit of a kludge fix. Well done
@sam_nazarko… is the Banding Issue now fixed in the latest march build ? For the first time i see also Banding in “Despicable Me” with the first march build!
We know how to resolve this now but there is a timing issue which is preventing us from fixing this without manual intervention. Rest assured – this is being worked on promptly and once I have some progress I will make it available here.
Are you in 10-bit mode? --> the 2018.02-1 update has the “echo “444,10bit” | sudo tee /sys/class/amhdmitx/amhdmitx0/attr” command build in?! i have this also in the rc.local!
Is the film HDR? --> yes!
Did you run this as root? --> yes!
Is your device up to date? --> i have installed the 2018.02-1 (not the 2018.03-2 update) - does the command " sudo echo round1 >/sys/class/amhdmitx/amhdmitx0/debug" also work with this build?
Does dmesg show feedback after you run this command? --> what feedback? After type in this command the only feedback is a new line in the shell…
Ok… will do that… is there any way to automate the command via startscript or something? To start a movie in the homecinema, put on the pc, logon to the vero and type in the command every movie again isn´t very usefull!
And is the 10-bit command in the rc.local also necessary after install the february or march update?
