HDR color shifting/flickering on vero 4k
Im experiencing a color shift/flicker/dither(?) When playing hdr content on the vero 4k+
Its mostly noticeable in greys and darker scenes, and it can become quite a bit brighter and very noticeable
I saw a similar thread from around 5-6 years ago about a similar issue, with some workarounds but was wondering if there was any solution to the issue, or any setting I should change?
I was hoping theres some solution rather than a workaround
Im using an lg c1
Linking thread for reference HDR Slight flickering (Workaround available)
Thanks in advance
Can you confirm that you’re on the latest version of OSMC?
Is Vero connected directly to the display or going through another piece of equipment like an AV receiver?
Does the issue occur on all content or just some?
I’m on veraion 2023.05-1 kernel 4.9.269-26-osmc
I think its happening everywhere where the content is 4k hdr? Maybe hevc more specifically? I’ll look for some of my x264 content
And vero is connected directly
@sam_nazarko do you have any clue what might be the issue?
Not without any logs or further information, no.
What info exactly should i get and how?
Where are logs stored?
