Hi guys,
Could anybody please download this clip and check if when played on the Vero4k it’s flagged as HDR?
This is the mediainfo:
General
Complete name : The World in HDR in 4K (ULTRA HD)-tO01J-M3g0U.webm
Format : WebM
Format version : Version 4 / Version 2
File size : 531 MiB
Duration : 2 min 34 s
Overall bit rate : 28.8 Mb/s
Writing application : Lavf57.83.100
Writing library : Lavf57.83.100
Video
Format : VP9
Codec ID : V_VP9
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 FPS
Color space : YUV
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Audio
Format : Opus
Codec ID : A_OPUS
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Bit depth : 32 bits
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
When I play it directly using the Youtube app on my TV the image quality/colors are what I’d expect from 4K/HDR however when I play the dump on the Vero which is connected to the same TV it’s not flagged as HDR and the colors are poor.
Thanks ![]()
