Just noticed that when starting a UHD HDR movie or TV episode, my TV is not detecting HDR , the TV status show bt.709…if I leave it playing and manually reselect the HDMI input, HDR is detected, the TV status correctly shows bt.2020
Its been a while since I played any HDR content so im not sure when this problem started.
Sorry if this sounds stupid, but when HDR doesn’t work, and when it does, can you confirm that you’re playing the same file (so as not to introduce further variables)
Yeah its the same file Sam.
Every HDR file I own is doing the same thing, HDR is never autodetected by the TV, but will always be detected if I reselect the HDMI input on the TV.
Im 100% sure the TV used to auto detect the HDR file a short while ago, exactly when this stopped working I cant pinpoint unfortunately.
OK, so we are sending HDR10. Can you detect if your TV is actually playing it as HDR10? It may only report on-screen when there is a mode change, not when there is a metadata change (InfoFrame).
Right, so from what I can tell, the colours look fine, even though the status screen isn’t reporting it correctly.
Whats strange is if I leave the status page up on the TV, and use the web interface to control the Vero, when I start a HDR film, the status page correctly updates, yet if I use the TV remote to control the Vero, like I normally would, and then bring up the status screen, more often than not it will incorrectly report the HDR status.
I definitely remember the HDR logo used to come up when starting a HDR movie, but as you say, it could well be the change to Leia introduced this.
Indeed. It shouldn’t be a problem in practice but we’ll see if we can make it work how it used to without introducing more delay to the resolution switching.
That’d be great Graham, cheers for your assistance on this, Im confident its now just the TV reporting it incorrectly rather than the TV not detecting HDR.
Just for closure on this issue, after the latest OSMC update my TV is now behaving exactly as it used to…when I start playing HDR content I get the ‘HDR’ notification on my TV every time now.
