Thanks for any assistance on this.
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.13-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Sun May 17 18:50:26 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 809abd80, node_mem_map ae213000
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8640->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ae1e1000 s12096 r8192 d20672 u40960
[ 0.000000] pcpu-alloc: s12096 r8192 d20672 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 191008
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2709.boardrev=0xa21041 bcm2709.serial=0xcba26f61 smsc95xx.macaddr=B8:27:EB:A2:6F:61 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 744108K/770048K available (7249K kernel code, 401K rwdata, 1864K rodata, 388K init, 763K bss, 25940K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x808ee928 (9115 kB)
.init : 0x808ef000 - 0x80950000 ( 388 kB)
.data : 0x80950000 - 0x809b465c ( 402 kB)
.bss : 0x809b465c - 0x80a73594 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000014] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000036] Switching to timer-based delay loop, resolution 52ns
[ 0.000319] Console: colour dummy device 80x30
[ 0.000521] console [tty0] enabled
[ 0.000546] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000574] pid_max: default: 32768 minimum: 301
[ 0.000959] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000980] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002202] Initializing cgroup subsys memory
[ 0.002252] Initializing cgroup subsys devices
[ 0.002277] Initializing cgroup subsys freezer
[ 0.002300] Initializing cgroup subsys net_cls
[ 0.002336] Initializing cgroup subsys blkio
[ 0.002418] CPU: Testing write buffer coherency: ok
[ 0.002496] ftrace: allocating 18151 entries in 54 pages
[ 0.046715] CPU0: update cpu_capacity 1024
[ 0.046752] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.046772] [bcm2709_smp_prepare_cpus] enter
[ 0.046914] Setting up static identity map for 0x6aeea8 - 0x6aef00
[ 0.106650] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.106948] CPU1: Booted secondary processor
[ 0.106956] [bcm2709_secondary_init] enter cpu:1
[ 0.107012] CPU1: update cpu_capacity 1024
[ 0.107020] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.126630] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.126885] CPU2: Booted secondary processor
[ 0.126892] [bcm2709_secondary_init] enter cpu:2
[ 0.126923] CPU2: update cpu_capacity 1024
[ 0.126931] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.146663] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.146906] CPU3: Booted secondary processor
[ 0.146912] [bcm2709_secondary_init] enter cpu:3
[ 0.146942] CPU3: update cpu_capacity 1024
[ 0.146951] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.147045] Brought up 4 CPUs
[ 0.147079] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.147089] CPU: All CPU(s) started in SVC mode.
[ 0.148096] devtmpfs: initialized
[ 0.173051] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.175076] pinctrl core: initialized pinctrl subsystem
[ 0.178154] NET: Registered protocol family 16
[ 0.183500] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.206468] cpuidle: using governor ladder
[ 0.236492] cpuidle: using governor menu
[ 0.236626] bcm2709.uart_clock = 3000000
[ 0.239534] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.239555] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.239588] mailbox: Broadcom VideoCore Mailbox driver
[ 0.239711] bcm2708_vcio: mailbox at f300b880
[ 0.240034] bcm_power: Broadcom power driver
[ 0.240051] bcm_power_open() → 0
[ 0.240062] bcm_power_request(0, 8)
[ 0.740727] bcm_mailbox_read → 00000080, 0
[ 0.740740] bcm_power_request → 0
[ 0.740859] Serial: AMBA PL011 UART driver
[ 0.741000] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.809055] SCSI subsystem initialized
[ 0.809296] usbcore: registered new interface driver usbfs
[ 0.809410] usbcore: registered new interface driver hub
[ 0.809555] usbcore: registered new device driver usb
[ 0.811193] Switched to clocksource arch_sys_counter
[ 0.838700] FS-Cache: Loaded
[ 0.839022] CacheFiles: Loaded
[ 0.850692] NET: Registered protocol family 2
[ 0.852098] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.852243] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.852436] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.852544] TCP: reno registered
[ 0.852567] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.852630] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.853107] NET: Registered protocol family 1
[ 0.853534] RPC: Registered named UNIX socket transport module.
[ 0.853551] RPC: Registered udp transport module.
[ 0.853562] RPC: Registered tcp transport module.
[ 0.853573] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.854034] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.854258] bcm2708_dma: DMA manager at f3007000
[ 0.854415] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.856036] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.856266] audit: initializing netlink subsys (disabled)
[ 0.856331] audit: type=2000 audit(0.829:1): initialized
[ 0.872203] VFS: Disk quotas dquot_6.5.2
[ 0.872584] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.875557] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.876532] NFS: Registering the id_resolver key type
[ 0.876604] Key type id_resolver registered
[ 0.876617] Key type id_legacy registered
[ 0.877650] msgmni has been set to 1469
[ 0.879664] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.879848] io scheduler noop registered
[ 0.880163] io scheduler bfq registered (default)
[ 0.880174] BFQ I/O-scheduler version: v7r7
[ 0.882665] BCM2708FB: allocated DMA memory eec00000
[ 0.882709] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.898478] Console: switching to colour frame buffer device 160x45
[ 0.909117] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.909402] uart-pl011 dev:f1: no DMA platform data
[ 0.909898] vc-cma: Videocore CMA driver
[ 0.909913] vc-cma: vc_cma_base = 0x00000000
[ 0.909925] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.909935] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.921445] brd: module loaded
[ 0.927262] loop: module loaded
[ 0.928069] vchiq: vchiq_init_state: slot_zero = 0xaec80000, is_master = 0
[ 0.928904] Loading iSCSI transport class v2.0-870.
[ 0.929830] usbcore: registered new interface driver smsc95xx
[ 0.929905] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.130246] Core Release: 2.80a
[ 1.130270] Setting default values for core params
[ 1.130296] Finished setting default values for core params
[ 1.330702] Using Buffer DMA mode
[ 1.330719] Periodic Transfer Interrupt Enhancement - disabled
[ 1.330730] Multiprocessor Interrupt Enhancement - disabled
[ 1.330741] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.330757] Dedicated Tx FIFOs mode
[ 1.331123] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec14000 dma = 0xeec14000 len=9024
[ 1.331163] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.331224] dwc_otg: Microframe scheduler enabled
[ 1.331299] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x804f8c30
[ 1.331319] WARN::hcd_init_fiq:413: FIQ ASM at 0x804f8fa0 length 36
[ 1.331338] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf80a000
[ 1.331367] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.331418] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.331465] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.331519] Init: Port Power? op_state=1
[ 1.331530] Init: Power Port (0)
[ 1.331829] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.331850] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.331866] usb usb1: Product: DWC OTG Controller
[ 1.331882] usb usb1: Manufacturer: Linux 3.18.13-1-osmc dwc_otg_hcd
[ 1.331897] usb usb1: SerialNumber: bcm2708_usb
[ 1.332877] hub 1-0:1.0: USB hub found
[ 1.332941] hub 1-0:1.0: 1 port detected
[ 1.333457] dwc_otg: FIQ enabled
[ 1.333472] dwc_otg: NAK holdoff enabled
[ 1.333482] dwc_otg: FIQ split-transaction FSM enabled
[ 1.333522] Module dwc_common_port init
[ 1.333882] usbcore: registered new interface driver usb-storage
[ 1.334164] mousedev: PS/2 mouse device common for all mice
[ 1.335053] bcm2835-cpufreq: min=600000 max=900000
[ 1.335367] sdhci: Secure Digital Host Controller Interface driver
[ 1.335380] sdhci: Copyright(c) Pierre Ossman
[ 1.335563] DMA channels allocated for the MMC driver
[ 1.371225] Load BCM2835 MMC driver
[ 1.371521] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.375400] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.377747] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.378051] usbcore: registered new interface driver usbhid
[ 1.378064] usbhid: USB HID core driver
[ 1.379438] TCP: cubic registered
[ 1.379460] Initializing XFRM netlink socket
[ 1.379510] NET: Registered protocol family 17
[ 1.380761] Key type dns_resolver registered
[ 1.380939] Registering SWP/SWPB emulation handler
[ 1.384127] registered taskstats version 1
[ 1.387717] vc-sm: Videocore shared memory driver
[ 1.387739] [vc_sm_connected_init]: start
[ 1.388547] [vc_sm_connected_init]: end - returning 0
[ 1.389606] Waiting for root device /dev/mmcblk0p2…
[ 1.410499] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.413983] mmc0: new high speed SDHC card at address aaaa
[ 1.414572] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[ 1.416041] mmcblk0: p1 p2
[ 1.507680] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.507751] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.517950] devtmpfs: mounted
[ 1.518614] Freeing unused kernel memory: 388K (808ef000 - 80950000)
[ 1.531354] Indeed it is in host mode hprt0 = 00021501
[ 1.711351] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.711517] Indeed it is in host mode hprt0 = 00001101
[ 1.911671] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.911703] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.912759] hub 1-1:1.0: USB hub found
[ 1.912880] hub 1-1:1.0: 5 ports detected
[ 2.191469] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.291674] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.291704] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.294801] smsc95xx v1.0.4
[ 2.355341] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a2:6f:61
[ 2.431460] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.532329] usb 1-1.2: New USB device found, idVendor=20f4, idProduct=804b
[ 2.532361] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.532377] usb 1-1.2: Product: 802.11n WLAN Adapter
[ 2.532392] usb 1-1.2: Manufacturer: Realtek
[ 2.532408] usb 1-1.2: SerialNumber: 00e04c000001
[ 2.611450] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ 2.769031] usb 1-1.3: New USB device found, idVendor=05a4, idProduct=9881
[ 2.769065] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.808288] input: HID 05a4:9881 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:05A4:9881.0001/input/input0
[ 2.808729] hid-generic 0003:05A4:9881.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 05a4:9881] on usb-bcm2708_usb-1.3/input0
[ 2.932851] input: HID 05a4:9881 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:05A4:9881.0002/input/input1
[ 2.933492] hid-generic 0003:05A4:9881.0002: input,hidraw1: USB HID v1.10 Mouse [HID 05a4:9881] on usb-bcm2708_usb-1.3/input1
[ 3.206813] random: systemd urandom read with 88 bits of entropy available
[ 3.264015] NET: Registered protocol family 10
[ 3.588265] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.588583] systemd[1]: Found ordering cycle on basic.target/start
[ 3.588612] systemd[1]: Found dependency on sysinit.target/start
[ 3.588640] systemd[1]: Found dependency on kbd.service/start
[ 3.588667] systemd[1]: Found dependency on remote-fs.target/start
[ 3.588692] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 3.588717] systemd[1]: Found dependency on connman.service/start
[ 3.588741] systemd[1]: Found dependency on dbus.service/start
[ 3.588765] systemd[1]: Found dependency on basic.target/start
[ 3.588791] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 3.588821] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.589168] systemd[1]: Found ordering cycle on basic.target/start
[ 3.589201] systemd[1]: Found dependency on sysinit.target/start
[ 3.589229] systemd[1]: Found dependency on rpcbind.service/start
[ 3.589258] systemd[1]: Found dependency on network-online.target/start
[ 3.589283] systemd[1]: Found dependency on network.target/start
[ 3.589306] systemd[1]: Found dependency on connman.service/start
[ 3.589330] systemd[1]: Found dependency on dbus.service/start
[ 3.589354] systemd[1]: Found dependency on basic.target/start
[ 3.589379] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 3.589409] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.775192] fuse init (API version 7.23)
[ 3.777613] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.129338] systemd-udevd[130]: starting version 215
[ 4.332149] lirc_dev: IR Remote Control driver registered, major 246
[ 4.433442] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.611785] random: nonblocking pool is initialized
[ 4.743933] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.391287] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 5.391767] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 5.391790] lirc_rpi: driver registered!
[ 5.615463] input: lircd as /devices/virtual/input/input2
[ 5.811823] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ 6.283475] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 6.283935] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.982917] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.989961] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 8.015426] 8021q: 802.1Q VLAN Support v1.8
[ 11.719752] Console: switching to colour dummy device 80x30
