Since a week or two I’m having heat issues with my rpi3 running the latest osmc (and sonarr, nzbget,cp)
Anyone else having these issues?
I’m not aware any other reports of heating issue with the pi3, so;
reboot the OSMC device
reproduce the issue
upload the log set either using the
Tom
I know that this is. Will fix it shortly and send you some test instructions.
https://paste.osmc.tv/haxadexuqi
P.S. this was after I unplugged everything from the pi and let it cool down, then rebooted.
I don’t have the “thermometer” symbol anymore, so not sure if the log will be helpful.
I don’t need any logs. Aware of the problem
Thanks Sam, u da man!
Is running the pi while being so hot bad for the device? I assume it uses more power since something is running at max. Performance, right?
Although the general wisdom is that running a CPU hot reduces its lifespan it shouldn’t really be of any concern as it will most likely outlive other components on that board anyway, It’s been awhile since I last read up on the subject but I think with PC CPU’s they were talking about losing a couple years off of a couple decades of running 24/7. The RPi monitors its temperature and will throttle itself back if needed to stay within operating specs. The only time this doesn’t happen is if you set force turbo, which you didn’t, so I wouldn’t worry about it.
You can keep an eye on your temperature by entering the command line below (by using an SSH client)
/opt/vc/bin/vcgencmd measure_temp
Thanks!
62.3 C… not doing anything with the pi right now.
Normal temperature?
Same issue again. Not playing anything, idle osmc. Temp is 80.6 C.
Any news Sam?
I haven’t had a chance to address this yet.
This has now been solved.
