I have a Raspberry Pi 3 since 1 year ago and the power supply (non original) is starting to fail now because the fan installed is not working properly when I put it on.
I looked in Amazon Spain and I found this power supply.
Will that work on my RPi 3? It needs to feed the fan and a Toshiba Canvio Basics of 1TB and sometimes that one and other of 3TB.
Also, I found this on/off button but I don’t know if this is recommendable.
I searched in Amazon because I have a Prime account there. Thanks for the first link but why do you prefer the OSMC one instead of the official one? I know that it’s cheaper and OSMC is a good brand but I want to know why.
About the second link, that is for a UK plug and I live in Spain. But thanks.
Hi @antonio8909!Any feedback for your osmc power adapter for raspi 3?I want to buy it think its pretty cool and good quality.So many adapters out there
I still have the same power issues. It didn’t change. For avoid it you need to buy the OSMC USB 3.0 hub for get all power but I’m not going to buy it for now.
Thanks for your fast answer my friend!I was planning to use Raspi 3 maybe as NAS(i am still waiting for it).Or just as pc with raspbian.So i dont know what to choose.I think even the official power supply wouldn’t solve your power issues @antonio8909.Its the HDD that needs more juice…HUB is the best way to go imo.Generally how did you find the osmc power adapter?Solid?Good quality compared to your previous?It has 2 years warranty pretty cool.
The supply is good but it does the same that my old one. Same energy input and output. You can give it a try but it doesnt satisfy my needs 100% until I but a hub in a store or something.
