05:25:09 T:1589068832 ERROR: Unable to open database: xbmc_video90 [2013](Lost connection to MySQL server at 'reading initial communication packet', system error: 104)
(57 Unable to open database entries in 12 hours)
I also run Kodi/OSMC on a Raspbery Pi B+. It’s kodi.log has no such entries.
The Vero is using the built-in wireless, the B+ is wired to an Airport Express.
Would be interesting to know if power saving is doing this. I have plans to turn it off for most WLAN adapters in the next update
FYI, we move to kernel 4.x soon for Vero. One of the i.MX6 kernel developers jnettlet comments that 4.x’s Broadcom driver brings much improved WiFi stability.
I’m tired of fiddling with it. This is not a hobiest’s toy, it’s a commercial product that should work as advertised out of the box.
It’s Sunday. My family wants to watch TV, not have me do endless command line diddling. I deployed the Airport Express so that they could have some non-buffered entertainment. I apologize for putting my family first.
When I have time and everyone else is at work or at school I may be inspired to turn the wireless interface back on and play with it.
The fact that you can stream 1080p through two walls seems to be ample demonstration that my Vero may be defective. I can also stream HD video through two concrete walls – using a Pi B+ and an old AirPort Extreme.
Did I ask for extra support? Not that I recall. I just want a product that works. I did extensive testing with iperf to demonstrate my Vero’s WiFi inadequacies. I’ve also provided log files.
Instead of real customer support I either get snark or get ignored. This is not the way to treat paying customers.
Last login: Mon Jul 6 08:21:32 2015 from 192.168.0.75
osmc@osmc:~$ sudo iwconfig wlan0 power off
sudo: iwconfig: command not found
osmc@osmc:~$
osmc@osmc:~$ which iwconfig
osmc@osmc:~$
osmc@osmc:~$ sudo apt-get install iwconfig
Reading package lists... Done
Building dependency tree
E: Unable to locate package iwconfig
Before you scold me again, please have a look at my posts in this thread which, I believe, demonstrate that I am willing to spend some time and take some trouble to work this out:
As for yesterday, you berated me for responding to a post but note being willing to “run a single line”. At that time my family was using the Vero to watch videos. I was not watching. I did have time to respond to this thread, but I was not willing to ask them to stop watching TV so that Dad could reconfigure the network and reboot the machine.
Keep in mind that not all of us are full-time geeks. Some of us have actual lives to live and families to care for.
Thats fine, but you responded to Sam’s suggestion without even a single acknowledgement of it. No, “I will try that” or anything. But you did manage to find the space and time to reiterate a prior complaint.
I thought that my explanation that I had disabled the WiFi adapter and deployed the Airport Express was response enough.
Anyway, as you can see, I can’t run Sam’s suggested command. Although, try I did, as promised.
And, since Sam has confirmed that the WiFi signal cannot be improved, there’s really no point in going on.
The Vero works fine wired to the Airport Express. I’m sorry that I wasted so much time fooling with the built-in WiFi adapter. I should have deployed the AE sooner. Less hassle. Less grief.
I am, however, still curious as to why you can stream 1080p video through two walls and I can’t even stream 480p (with the Vero on WiFi) three meters through a quarter inch thick wooden stereo cabinet.
Keep in mind that I can stream 720p video to
An Apple TV which sits right above the Vero
An iPad anywhere in the house
A Pi B+/Airport Express separated from the router by 10 meters and two concrete walls
The Vero when wired to an Airport Express
There has to be a rational explanation as to why yours works and mine doesn’t.
When you respond to someone without addressing what they just said, you cant complain when people think you are ignoring them.
I suspect I can stream through two walls because they are simply timber framing and plasterboard, here are no wires or pipes running through them, and there is nothing else around that can cause interference.
Now, this is odd. I was away from home for a while. When I got back the Vero had lost the wireless connection. I was unable to SSH in. Had to cycle the power for it to acquire an IP address.
Thank you. That worked. I have now executed the requested command.
That really doesn’t explain it. I suspect that your Vero is more than three meters away from your router.
I’m only three meters and the only barrier is a thin piece of teak on the end of my stereo cabinet.
You can stream 1080p and I get buffering with 480p.
It makes no logical sense.
You mean kind of the way you responded to me but ignored the important part of my post where I showed that the iwconfig command wasn’t installed on my Vero?
Pfft. Hardly. I dont know jack about networking. What am I going to do? Tell you to try turning it off and on again?
Quite frankly, I dont give a shit about your wifi, or about any problems you are having. It’s not my
department. But you were offered a potential solution and you ignored it completely to keep on complaining.
How about you go back and look at your post, the one right after Sam’s. Notice how you didnt even respond to a single thing he said. People who do that sort of thing are showing everybody that they care more about complaining, than solving their problem.
Thanks for that – I will make the power saving disabled by default in the future and hope kernel 4.x with the new Broadcom driver can bring some improvements too
