Hope there are anyone who give me some tip about my problem.
When I want to view pictures with ‘slideshow’ - I have from before set the amount of time for each picture being viewed.
But - it does not correspond with the time set…!
When I chose the setting to 10 seconds => it shows each picture in a approx. 5 seconds
I changed setting to 15 seconds => it shows each picture in almost 10 seconds
So I decided to do another try - then set it to 25 seconds => it shows each picture in 17 seconds.
This ‘failure’ happened after a ‘hang’ on the OS and had to reboot the system.
Then - after that, I need to go through all the settings again after booted up.
(Some settings are the same, but other I need to go through and set again).
I tried to ‘shut down’ and let it be without power for a while and started again.
Yes…it works, but still the counter is not correct and I also need to go through and change settings, like background for main screen and some other settings.
Anyone who can have an idea waht can be wrong.??
Appreciated for all help.!
