The log file don’t directly show any crash information.
I am not knowledgeable in the Addon you are using but wonder if you instead could use tvheadend which seems also to support movistar
Of course I could use Tvheadend (I was using it before), the “problem” is that it requires a lot of work to configure it in one side, and in the other side this add-on gives much more functionalities like a real deco from the company that Tvheadend doesn´t allow, that´s why I´d like to install this add-on.
Is there anyone who could try to install this add-on on its Rpi (I could explain to him how) and see if it gets the same failure?
